 Hyundai-Forums.com > Hyundai Models > Azera Forum
> 3.8 Hp On The Azera Vs The Genesis, heads
Sleasy
post Jul 3 2008, 08:11 PM
Drives: 2003 Tiburon GT, 2007 Azera Ultimate
The valve train on the 3.3 V6 and the 3.8 V6 in the Azera are the same. The valve sizes are identical. I think this explains the reason why the 3.3 delivers more HP per liter than the 3.8. It also explains the 300+ HP being developed by the Genesis 3.8 V6. New valve train actually made for the 3.8. Not sure if different cams are being used. Yes, I know it's spelled Genesis.
Fixed ~ madderhatter :thumbsup:
This post has been edited by madderhatter: Jul 11 2008, 07:43 PM
joezera
post Jul 7 2008, 07:16 AM
Drives: '07Azera Ltd, Premium, 3.8L V6; Dodge Ram 5.9L I-6
Are the bore and stroke the same on both engines? If so, the heads would be the only area left to make 3.8L of volume compared to the 3.3L. You could easily be correct, because manufacturers often use different heads to create different swirl patterns in the air-fuel mixture. The more active the swirl pattern, the more power that is extracted from the fuel. Just making the bore and stroke produce more volume doesn't necessarily create more power per cubic unit volume. There are lots of variables involved. Even placement of spark plugs has a noticeable effect on power output.
Joe
wfranklin
post Jul 9 2008, 07:15 PM
Drives: Auffenberg Hyundai
The 3.8L V6 in the Genesis pumps 290HP, not 300+. It's a complete brand new engine setup, and is in no way shape or form anything like the 3.8L in the Azera's and Veracruz. Same displacement, completely different engine.
andyman32
post Jul 9 2008, 07:19 PM
Expert
Drives: 07 Azera Ultimate #1, 07 Azera Ultimate #2, 96 Vanden Plas, 97 XJR
QUOTE(Sleasy @ Jul 3 2008, 09:11 PM)
[right][snapback]174003[/snapback][/right]
Is there a question in there?
Sleasy
post Jul 11 2008, 08:09 AM
QUOTE(wfranklin @ Jul 9 2008, 08:15 PM)
[right][snapback]175133[/snapback][/right]
The 3.8 L in the Genesis Coupe running on premium gas is supposed to be 300 +HP, I think. Regardless, whether it's 290 or 300, the output is still +10% over the 3.8L inb the Azera.
Where did you get the information that the 3.8 L in the Genesis is "completely" different than the 3.8L in the Azera? I find that very hard to believe.
I do know that the 3.3L and the 3.8L V6 in the Azera share the same valve sizes. I believe it explains the diffence in output per liter for the two engines.
Pelikan
post Jul 11 2008, 09:02 AM
Drives: Azera2006 OutBack 2001
I too don't believe that it's a brand new engine (too expensive to develop) it could be the same as the Azera with a rebore and a different head, but if the same displacement it's most likely only a different head.
boostedfc3s
post Jul 11 2008, 10:39 AM
Expert
Status: Online
Drives: 2006 Azera Limited Ultimate Pkg V6 3.8L
It's probably got a re tuned computer.
Precious Metal T...
post Jul 25 2008, 02:53 PM
Drives: 2007 Azera Limited, 2008 Veracruz Limited
Wfranklin is correct, it is not the same engine.
It's very close to the Azera, Veracruz, and Entourage but very few parts are interchangable with the Genesis 3.8. The block was redesigned to strengthen areas for longitudinal mounting, and for changes to the cylinder heads. Most of the changes were made in the cylinder head. The new heads have CVVT on intake and exhaust cams, as opposed to only in the intake cams on the previous 3.8. Coolant passages in block, but mainly in the cylinder head have been reworked. Intake manifold and exhaust are obviously not the same due to the N/S engine mounting. These changes along with PCM tuning account for the increased HP.
mkaresh
post Aug 7 2008, 01:25 PM
Drives: 2003 Mazda Protege5
Different valve timing = different outputs. Also might have a less restrictive intake and exhaust.
If the valve sizes are the same in the 3.3 and 3.8, then the bore is the same but the stroke is different. Both can't be the same, because displacement is calculated from bore and stroke. Changing the heads can change the compression ratio and combustion chamber volume, but not the displacement.
No New Posts The Genesis Alternative... For Less
21 07 Santa Fe 1,182 Yesterday, 08:57 PM
Last post by: 8sonny
No New Posts Topic has attachmentsGenesis Wheels
6 brihvac 65 Yesterday, 02:52 PM
Last post by: ironman
No new Topic has attachmentsThe Effects Of Going 100+ Mph In A Sonata
"There has been a fatality. The guy is in half"
102 alex2006sonata 1,375 28th November 2008 - 11:18 PM
Last post by: hugamuto
No New Posts The Multifunction Car Dvd Player Cdp0005
0 timusacs 12 28th November 2008 - 12:02 AM
Last post by: timusacs
No New Posts The Horn..
and no.. not how it sounds... hehe
5 Pinto_Siftbean 88 27th November 2008 - 09:47 PM
Last post by: david-paul-1
2nd December 2008 - 01:27 AM
