| byronguidry3732 |
Jul 1 2008, 05:59 PM
Group: Super Mod
Drives: 2003 Tiburon GT 2.7, 2004 Santa FE FWD 2.7, 2001 Sonata 2.4, 2000 Elantra, 1984 Pontiac Fiero SE Status: OFFLINE
Dear 273, P0304 Cylinder 4 misfire detected Causes: ● Vacuum leak in air intake system ● CKPS circuit malfunction ● Ignition circuit malfunction ● Faulty ignition coil or pulg wire ● Spark plug malfunction ● Low compression due to blown head gasket, leaking valve or piston ring ● Low/high fuel pressure due to faulty ● pressure regulator,restricted fuel lines,plugged fuel filter or faulty fuel pump ● Fuel injector circuit malfunction ● Faulty fuel injector ● Faulty PCM P0441 Evap Emission System incorrect purge flow Causes: ● Open in battery circuit. ● Open in control circuit. ● Short to ground in control circuit ● Faulty PCSV ● Faulty PCM Nice picture:  Go to the HMA manual, DTC, and you get lots of nice pictures of the faulty items. Byron
| 273HYPO |
Aug 20 2008, 07:30 AM
Drives: 2004 Accent GLS Status: OFFLINE
QUOTE(273HYPO @ Aug 17 2008, 07:30 AM) The purge control solenoid valve controls the fuel vapor emissions. Just a hunch but when your filing up and its hard to start there maybe a correlation in which the the quantity of gas now in your tank is not vaporizing properly even though it hasn't given you the code again. Or it could be your charcoal cansiter near the fuel tank which is pricey to repair. I would go ahead and replace the purge control valve since that was the initial code. I got mine for $37. from the dealer and less than two minutes to repair. Keep us posted. 273HYPO WOW...$78 bucks.....try ebay, I saw one there when I got mine for $34. + $10. bucks s&h.
Track this topic
Subscribe to this forum
Download / Print this Topic
Link To Us
Similar Threads
Similar Threads
7th September 2008 - 03:24 PM |
