Ok, I went out and played with mine earlier... If you arm the system with the remote, you can unlock it with the key and get in the car without setting off the alarm system. However, if you sit in the car and arm the system, then open one of the doors from the inside (without unlocking it), then the alarm goes off. Also, the system does not have a starter disable feature, so it is simply a keyless entry system with intrusion alarm. It also does not have any kind of motion sensors (rocking or jacking of the car, etc).
