 Hyundai-Forums.com > Hyundai Models > Santa Fe Forum > 1G (2001-2006) Santa Fe > Changing Front Brake Pads On 2003 Santafe Question
 Changing Front Brake Pads On 2003 Santafe Question, repair
boog
post Jun 28 2008, 05:25 PM
Drives: 2003 Hyundai Santa Fe
Status: OFFLINE
I'm changing my front brake pads out on my 2003 SantaFe today and I was wondering if there are any things I need to watch out for or be carefull with?
I've done minor repair work on other vehicles with one other disc brake pad replacement on another vehicle we own. The brake pad replacement seemd rather straightforward when I did it.
Is there anything specific to the SantaFe that I need to be carefull with or is it basically the same procedure? Such as any torque specs I have to worry about for the wheel lug nuts or any of the brake caliper hardware?
Is there a step by step procedure that I can reference?
This post has been edited by boog: Jun 28 2008, 05:49 PM
User is offlineProfile CardPM
QuoteReply
LilBean
post Jun 28 2008, 05:50 PM
Status: OFFLINE
There's nothing especially different about Hyundai's front discs, unless you are unlucky enough to have an early model Tiburon or Elantra with captive rotors. Your Santa Fe shouldn't be any different than any other disc brakes you've done. Just take your time and do it right. Takes longer to put it in the air and take the wheels off than it does to change the pads out.
The last time I took off a front caliper on my old 01 Tiburon, I cross threaded one of the bolts that holds the caliper to the bracket because I got in a hurry. Nearly cost me a new caliper.
QuoteReply
boog
post Jun 28 2008, 08:36 PM
Status: OFFLINE
Well one guy at one store says the 2003 SantaFe 2.7L V6 takes ceramic pads as an original stock replacement pad.
One guy at another store didn't know and recommended the semi-metallic pads.
So which is it and where do I find out that info??
(aside from calling the dealer)
QuoteReply
LilBean
post Jun 28 2008, 09:31 PM
Status: OFFLINE
QUOTE(boog @ Jun 28 2008, 08:36 PM)
I work in Hyundai Parts, and I'll tell you they aren't ceramic pads. No Hyundai comes with ceramic pads. Sure, you can use ceramic as a replacement, but that's not what the OEM pad is made of.
QuoteReply
boog
post Jun 28 2008, 09:49 PM
Status: OFFLINE
So then, what's the advice?
semi-metallic?
Is that what the OEM part is?
QuoteReply
LilBean
post Jun 29 2008, 11:34 AM
Status: OFFLINE
yes semi-metallic
QuoteReply
boog
post Jun 29 2008, 07:05 PM
Status: OFFLINE
Ok.. Got the pads. I've looked online and some pad replacement procedures call for grease on the pad, and some don't mention it.
Can you clear this up for me please?
What type of grease and exactly where do I apply it when I replace my front/rear disc brake pads? Applying grease to brake pads makes no sense to me.
Thanks for all the help so far.
QuoteReply
LilBean
post Jun 30 2008, 11:01 AM
Status: OFFLINE
It's not grease, it's an anti-squeal compound applied to the BACK of the pads, NOT THE FRICTION SURFACE... I'm sure you know that though... It's not neccessary, but some people prefer to use it.
It may be referring to putting grease on the caliper slide pins just as a maintenance item while you have it all apart.
QuoteReply
> Link To Us
> Similar Threads
3rd Brake Light Housing - Removal
Forum : 4G (2006+) Sonata
dd716ted 1 0 Today, 11:49 AM
By: dd716ted
Pm System Question ?
Forum : Board Questions, Feedback and Suggestions
cjrsonata 5 0 Today, 10:53 AM
By: cjrsonata
Changing Tail Light Bulbs
Forum : 2G (2000-2005) Accent
ebluekeys 20 1 Today, 10:21 AM
By: TommyR
Cooling Fan Question
Forum : 3G (2006+) Accent
ACCENTUATEthe+ 57 6 Today, 10:00 AM
By: bloodninja
Disabling Front Airbags
Forum : General Hyundai Non-Model Specific Discussion
Dave.c 12 0 Yesterday, 04:23 PM
By: Dave.c
7th September 2008 - 12:04 PM
