Alright so on my way home i blew my amplifier fuse for my subs and now when i stop at a light the engine speed drops than goes up to about 1500 rpm than down than back up and eventually stalls. I can do the left on brakes, right on gas but that sucks.
The weird thing is, when its cold and i start it, it will be fine. Put it into gear without moving, good. Let off the brakes and crawl, good. Drive for twenty feet than stop, not good.
I looked around and the only thing i can find that may be a problem would be the idle air valve. I heard you can clean it, but im not positive where its located. I was also wondering if it would do anything if i disconnected it.
Share your thoughts
