Dear Paul,
Just noticed that you had not been answered.
Since the location of the noise is not readily apparent, next time it starts the high pitched whistle get a long bladed screwdriver, start by touching the blade tip gently to the A/C tubing, put your ear to the handle, and see if the noise is loudest from that location. Try touching other areas and listening. touch the blade to the compressor and listen. touch the top of the radiator and listen. touch the valve cover and listen. Especially try to listen next to the high pressure and low pressure A/C couplings.
Once you have located the source, it could be a leaking A/C coupling, a pin hole in your A/C line, or something in your cooling system.
Byron
