> Spark Plugs For Our Cars
Komptek
post Jun 25 2008, 04:15 AM
AMSOIL T1 Direct Dealer
Drives: '07 Accent SR, '08 Santa Fe Limited
Well I cross referanced the plug and looks like it's the NGK Part#BKR6E-11 or amsoil Part#NGK2756 for our cars. Surprized me because I figured it would have been the as the pre MC engine, but I was wrong.
hoosieraccent
post Jun 25 2008, 08:29 AM
Drives: 06 accent
I've got NGK BR5ES-11 in mine, which is what the service manual called for...
Komptek
post Jun 25 2008, 11:17 AM
Yah after abotu a hour of research I found out there are like 20 differant plugs that can work in our cars, just depends on the application.
nobodieshero07
post Jun 25 2008, 08:26 PM
Drives: 2008 accent sport
aint it weird that the series letters for the amsoil plugs are NGK...
DWFan
post Jun 28 2008, 06:01 PM
Drives: 2007 Hyundai Accent SE
I just installed a set of LSG-BRISK plugs to replace the OEM Champions. So far so good. Time will tell though.
SSedan
post Jul 2 2008, 09:57 AM
Drives: 07 Accent GL comfort w/auto
QUOTE(hoosieraccent @ Jun 25 2008, 08:29 AM)
[right][snapback]172164[/snapback][/right]
Dealer just sold me NGK BKR5EY-11. I know the codes all match except the 'Y'. Anyone know the difference between the 'S'and the 'Y'.
r4square
post Jul 2 2008, 01:13 PM
Drives: 2007 Accent Sport Hatchback
QUOTE(SSedan @ Jul 2 2008, 07:57 AM)
[right][snapback]173668[/snapback][/right]
According to the NGK part code guide:
S = Standard 2.5mm Centre Electrode
Y = V-Grooved Center Electrode (14 mm only) 2.5 mm Insulator
Audioquest
post Jul 3 2008, 01:26 PM
Drives: 2007 Hyundai Accent GS Hatchback
Don't waste your money on "trick" plugs - stick with stock: NGK BKR5EY-11 or Champion RC10YC. Remember, there is only as much spark as the coil creates. Stick with copper plugs, change them every two years, and you'll achieve maximum performance.
nobodieshero07
post Jul 3 2008, 02:25 PM
QUOTE(Audioquest @ Jul 3 2008, 12:26 PM)
[right][snapback]173922[/snapback][/right]
the coil part i can beleive but... copper wont give you the best spark. things that are solid or coated in platnium will more efficently( sp) distribute the current into a more powerul and explosive spark. just cuse your coil gives off 20000 volts doesnt mean that your plugs are making good use of it
TOOSLO
post Jul 3 2008, 07:45 PM
AMSOIL T-1 CERTIFIED DEALER
Drives: 2007 hyundai accent gs 3dr auto
ngk iridium IX plugs in mine!
nothing but the best for her!
roadranger
post Jul 3 2008, 07:52 PM
Post #11
Drives: 2008 Hyundai Accent SE 5 spd.
Where are you guys getting your NGK plugs?
I've tried Advanced Auto, Checker, and Autozone...none of them can get the NGK plugs.
What's up with that?
Also, how do you change out the plugs with those coil thingies on top of them?
hoosieraccent
post Jul 3 2008, 10:33 PM
Post #12
Drives: 06 accent
Very strange, roadranger... I went into Advance and bought the plugs there! That was a year ago though, things change I guess... :puzzled:
All you have to do is remove the bolt out of the coil and it pulls right off the plug. They you'll need a really long extension on your socket to get down to the plug.
nobodieshero07
post Jul 3 2008, 11:05 PM
Post #13
best that you disconnect the battery befor you touch anything near the coils
hyunnychub
post Jul 4 2008, 09:23 PM
Post #14
Drives: 2007 Accent 3 door 5 speed
i had the brisks, big waste of money no improvment and horrible miss after 20,000 kms
went back to ngks.
this was in my old 99 accent.
stick with copper, copper carries the best volatge compared to platniums.
plats only have a longer life span at a cost though of less voltage.
look it up pn the net, copper vs plat
This post has been edited by hyunnychub: Jul 4 2008, 09:27 PM
Komptek
post Jul 4 2008, 11:14 PM
Post #15
I went with the V-Power NGK's seems to be working good so far.
moonz
post Jul 5 2008, 06:06 PM
Post #16
Drives: 07 Accent GS
Pure Copper is a better conductor of electricity than pure platinum by a factor of about 5, but Platinum can tolerate about twice as much heat as Copper, before it melts, and Iridium has an even higher melting point than Platinum.
So...what is more important in sparkplug tip design...thermal conductivity?...or stability in a high-temp environment?
This post has been edited by moonz: Jul 5 2008, 06:19 PM
TOOSLO
post Jul 5 2008, 06:37 PM
Post #17
QUOTE(TOOSLO @ Jul 3 2008, 08:45 PM)
[right][snapback]173995[/snapback][/right]
check out my website in my signature....
orMy Webpage
:beer:
This post has been edited by TOOSLO: Jul 5 2008, 06:39 PM
Komptek
post Jul 5 2008, 06:46 PM
Post #18
If your none turbo go copper, if you go turbo you'llneed platium.
No New Posts Topic has attachmentsFormer Honda Accord Owners That Bought Sonata
11 Huffa 126 18th November 2008 - 0
