New Owner Oil Change Question |
Jun 25 2008, 10:25 AM
Status:
Drives: 2008 Sonata Limited / 2006 Elantra GT
QUOTE(ddix1026 @ Jun 25 2008, 09:33 AM) i said "usually", not "always".... of course there will be situations where the look of the oil isnt indicative of its performance, but getting it changed at 4,300 miles doing 95% highway driving typically isnt going to break down the oil as much as doing 4,300 miles of intense stop & go/city driving... [right][snapback]172174[/snapback][/right]
Again, just not backed up by evidence. The only activity that can really can cast one into the "severe" driving category is extended operations and extremely high temps. Stop and go traffic places no more demand on oil than highway loafing. The Consumer Reports study was tested (over 5 million miles by the way) using New York City cabs...if stop and go is considered severe...then NYC cabs would be off the charts. Even then, the study recommended sticking with the manufactures 7,500 oil change interval. After complete motor teardowns...there was zero measurable difference between early (ie 3k) and appropriate change intervals (ie 7,500). Oil analysis is not expensive and will show you that you motor is properly protected at 7,500 and way beyond. This isnt preaching...just an opinion backed by more than anecdotal evidence.
Jun 25 2008, 11:43 AM
Lonely Commuter
Status:
the "evidence" is the 2006 Hyundai Sonata Owners Manual....
from past personal experience, pushing my former vehicle too far with oil (my wife drove our ZX2 to about 9,000 miles without changing the oil) and guess what? our cam solenoid went bad as a direct result of having too much metal in the oil, causing the solenoid to go bad (stalling, sputtering) and lo and behold, $1,400 later after the solenoid was replaced, we decided not to push our cars past the recommended intervals.
Hyundai recommends 7,500 mile oil changes UNLESS you drive in the following "severe" conditions: (straight from the manual)
A-Repeatedly driving short distance of less than 5miles (8km) in normal temperature or less than 10 miles (16km) in freezing temperature B-Extensive engine idling or low speed driving for long distances C-Driving on rough, dusty, muddy, unpaved, graveled or salt- spread roads D-Driving in areas using salt or other corrosive materials or in very cold weather E-Driving in sandy areas F-Driving in heavy traffic area over 90°F (32°C) G-Driving on uphill, downhill, or mountain road H-Towing a Trailer, or using a camper, or roof rack I-Driving as a patrol car, taxi, other commercial use or vehicle towing J-Driving over 100 MPH (170 Km/h) K-Frequently driving in stop-and-go conditions
If you drive in any of the conditions listed above, their recommendation is "EVERY 3,000 MILES (4,800 KM) OR 3 MONTHS"
well, to me, that sounds like everything BUT highway driving... thanks for your input, but I will continue playing it safe, and getting my oil changed within 5,000 miles (even though i actually DO mostly highway driving)... to me $13k - $15k is a bit too much money for me to go and play around with the possibility that my car dies on me.. i cant afford a new one.. its called being more safe than sorry.... maybe if/when i change to Synth oil, i might push it to 7,500 or 8,000 miles.. but not until then
This post has been edited by ddix1026: Jun 25 2008, 11:44 AM
Jun 29 2008, 01:07 PM
Fagedaboudit!
Status:
Drives: 06 Sonata GLS V6 born on 2006-01-29
QUOTE(Keezer @ Jun 24 2008, 12:58 PM) I bought my 07 Sonata about six months ago and its finally due for an oil change. My question is do I have to take it to the dealer or can I take it to any decent lube place (ie not Jiffy Lube)?
I've lurked here a bit and thought I remembered reading something to the effect that filters for the 4G model were dealer exclusive or aftermarkets had some issues or something. Any info would be appreciated. I'd really not have to deal with the local dealer for something this minor if I can avoid it. [right][snapback]171893[/snapback][/right]
I think specialists are very hard to beat. When you need heart surgery, go to a heart surgeon. For knee surgery, go to an othopedist, etc. Oil change specialists are less likely to make mistakes than the dealer. That's because the dealer probably assigns the least skilled or newest employee to do the oil change duties. I had 3 botched oil changes at my dealer, and 1 was nearly fatal. I have had 4 oil changes at my local Oil-Xpress, and they did everything perfect. I have no idea what brand filter they use, and don't care. That's because I change filters every 6 months, and the aftermarket filters with the defective anti-drainback valve have been remedied.
This post has been edited by bobad: Jun 29 2008, 01:09 PM
Jul 1 2008, 09:26 AM
Status:
Drives: 2007 Sonata 3.3L V6
QUOTE(bobad @ Jun 29 2008, 02:07 PM) I think specialists are very hard to beat. When you need heart surgery, go to a heart surgeon. For knee surgery, go to an othopedist, etc. Oil change specialists are less likely to make mistakes than the dealer. That's because the dealer probably assigns the least skilled or newest employee to do the oil change duties.
I had 3 botched oil changes at my dealer, and 1 was nearly fatal. I have had 4 oil changes at my local Oil-Xpress, and they did everything perfect. I have no idea what brand filter they use, and don't care. That's because I change filters every 6 months, and the aftermarket filters with the defective anti-drainback valve have been remedied. [right][snapback]173067[/snapback][/right]
Thats a good point. In the end I just bought the filter from the dealer as it was only $10 and gave me a new crush washer that I wouldn't have had. Thanks for all the info
Similar Topics
Similar Topics
