Drives: 97 Accent 1.3 GSI Status: OFFLINE
I have a 97 Accent 1.3 & the washer motor has stopped working.
When we bought it a few months ago the washer motor wasnt working, it was jammed. Took about a minute to sort out.
After a while the motor would not work for the back window, only the windscreen (I presume thats a wiring problem). But last night it stopped working for the windscreen too. Has it jammed again or is it wiring? Any advice welcome!
Group: Super Mod
Drives: XG's (2001&2002) Status: OFFLINE
l'm afraid that the washer pumps that hyundai use for all the models are not very good and do not last long, you will likely need a new pump, there is an aftermarket one that fits the hyundai models which you can buy at any decent car spares outlets
I had a go at it yesterday, got to the motors easy but I cant get the switches off the motors, I couldnt find any little latch to do on them & no matter how hard I tried they wernt coming off!
Drives: 1998 Atoz+ 1.0 Status: OFFLINE
:) Hi You've probably sorted this by now (!) but my 1998 Atoz+ front screen washer stopped working (see separate post about this) and for an Atoz, the Halfords HWP15 pump (£15) fitted OK with very slightly modified wiring.
Re wiring, the Atoz pumps are hardwired in (no connector on the pump itself) and only have a connector about 8 inches along the wire. Each plastic connector has a little clip on it - pushing down the clip and then pulling the wire releases it. Accent may be different though!!!
