Hi deniz,
thank-you for the info. (Downloaded plans from HmaService)I started with the drivers side console kick panel,it has a screw cover that snaps into place with clockwise motion( HMA manuals only mention 1 screw,it also has two clips and a plastic wheel slot that the panel slides into)...screw cover broke when gently removed...also has two clips above the screw that are held on by tension and no way to reach them...they do make a nice pinging sound when they let loose into the recesses of the floor under the console.
No way to reach the clips as space under there is at a premium ,AC ,Airbag control and Vent ducting to name a few are tucked under this ashtray area.There wasnt a way to re-attach the clips as there is no access to them even if i had found them...this floor console must have been assembled first and then installed into the SF.
I tried nudging and bumping and the beating the ashtray door with no luck....left it alone for a day and then went back to it. i was nudging the door again the next day and then i tapped on then Passenger side of the Dash console at ashtray the level....door moved a bit...hit it again and it came open....i have no idea what is on this side to be able to release the stuck tray...there was only a few coins for parking in the tray, these were not the cause of it being jammed as near as i can tell.
Anyone know where a proper shop Manual can be purchase for the SF? HMA is a nice tool but i have found this lacking info each time i have used it. it seems to have mostly American specs as well.
