Hello all,
I spent weeks trying to find information on removing the stereo until I had a brainwave on how I might be able to do it without the correct keys. It turned out to be quite a simple solution.
Is anyone familiar with the backing plates for PCI/AGP slots on the backs of computers? Well, I work in IT and had a box full of flat ones - the perfect thickness to slot down the sides of the stereo.
The thing is, the stereo actually has two tabs on either side, about an inch in from the front, so I needed to use two backing plates on each side of the stereo in order to depress all four of the tabs and then the stereo slid out like a charm.
I'll try and do some sort of ASCII art thing here to show what the tabs look like:
CODE
Front View:
Side View:
Long story short, all you need is two very thin, flat metal plates which you can insert down the sides of the stereo to flatten both tabs, but the plates need to be almost the height of the stereo in order to do both tabs.
This post has been edited by davidpartay: Jun 19 2008, 06:08 PM
