Dear art,
You have a 10 year old Sonata. With the ATA and Mini fuses, a problem called thermal fatigue occurs when the car is advanced in age. Thermal fatigue can be a hairline crack that causes an intermittent fault or break in the fuse. These are sometimes literally a crack that is almost invisible. Found out the hard way with a 1991 Volvo.
Head to Autozone or Checker. Buy one of the combination fuse tester and fuse assortment kits. Buy the one that matches your car, which I think is the Mini fuses. The kit is about 16 bucks. Also, buy an extra box of 10 amp fuses as approximately 60% of your fuse box is 10 amp fuses. Start testing and replacing. This will solve your current electrical problem.
Byron
