> 2006 Sonata Lx V6 Grinding Sound, grinding sound while turning right
danciso
post Jun 17 2008, 02:34 AM
Drives: 2006 Sonata
Has anyone's Sonata every make a grinding sound while turning right. It has happen at several speeds. Sounds like the rubbing or grinding.
SonataRobbie
post Jun 17 2008, 03:28 AM
Jack of All Trades; Master of None
Drives: 2006 Hyundai Sonata GLS 3.3L V6 (DOB 11/08/05)
We'll need a little more information before we can try to diagnose your problem.
What area is the sound coming from?
Is it constant or intermittent?
Do you only hear it at startup, or only after the car is warmed up - or both?
When did the problem start (i.e. after a service visit or some other event)?
Try to provide as much detailed information as possible, and I'm sure we'd all be glad to help.
For the record, the only issues I've had with a grinding/rubbing noise is from the steering wheel. It's a rubbing sound like two pieces of plastic being rubbed together. It's a very faint sound and it's either gone away or I've gotten used to it. I know several other people have mentioned the same kind of issue, and the only known fix is a full steering wheel replacement (about $1,100 US, but covered if you're under warranty).
bobad
post Jun 17 2008, 07:45 AM
Fagedaboudit!
Drives: 06 Sonata GLS V6 born on 2006-01-29
QUOTE(danciso @ Jun 17 2008, 02:34 AM)
[right][snapback]169950[/snapback][/right]
Most common caues is CV joint worn out. Sometimes it's a wheel bearing gone dry, or just a tire.
How many miles on your Sonata? Are your CV joint boots intact, or ruptured?
rallyman
post Jun 17 2008, 08:28 AM
Drives: 2006 Hyundai Sonata GL V6 3.3
I may have something similar. The noise only happens while braking and turning at the same time such as when pulling up to a stop sign to turn right or when parking the car. The dealer insists it is not in the brakes. They tried replacing a lower ball joint but that didn't fix it.
They said they have had several other cars with the same issue and are trying different things to correct the problem including replacing tie rod ends and front struts. Once they find the repair that solves the problem they will make the repair to all the cars they have had in with this issue.
Apparently, it has been very hard for them to try and diagnose because they cannot get the noise to occur while the car is on a hoist only while driving and with the front end under some load due to braking. I'm hoping to hear something back within the next few days. They indicated that they had just replaced the front struts on one of the cars and it seemed to fix the situation but they wanted to get a report back from the owner after driving the car a bit to verify that the noise was completely gone.
I'll report back if there is any resolution.
danciso
post Jun 19 2008, 01:51 AM
Drives: 2006 Sonata
Thanks for the replies!!!
The grinding noise seems to happens the most after the car has been going about 40-60 mph and then I stop and make a right turn. The noise is a grinding/rubbing sound that kidda sounds like the brakes are worn or rock is stuck in there. The sound stops when I apply the brakes. The sound has also happened while I exiting off the freeway on a right handed loop. I took it to my dealer they said the could not reproduce it. So I took him for a ride and had no problem producing the sound for him. He said it sounded like I need new brakes. The car has 36k I wouldn't think it would need brakes yet. Thanks for any help!!!
This post has been edited by danciso: Jun 19 2008, 01:53 AM
MiamiLX
post Jun 19 2008, 02:00 AM
VALUED MEMBER
Status: Online
Is it a Metallic sound? I did have a rock stuck in a wheel which I could hear
at Slow speeds only, and it had nothing to do with turning. When the
Dealer cleaned my Brakes they wrecked them, and I returned at closing
time and got new Rotors put on. However with 36K you might need new Brakes.
They are supposed to squeal to let you know it might be Brake time! :thumbsup:
MiamiLX
post Jun 19 2008, 02:06 AM
VALUED MEMBER
Status: Online
QUOTE(SonataRobbie @ Jun 17 2008, 12:28 AM)
[right][snapback]169954[/snapback][/right]
I know you might not beleive me, as my vision is going, but...
I had a rubbing/squealing noise from the Steering Wheel, with or without the
Engine on, and it was a rubbing Backplate. Still have the R.O. somewhere!
CF7
post Jul 1 2008, 09:52 AM
Drives: 2006 Sonata LX 2.4
I have the same problem when I turn right hard, there is grinding noise .. Sound is traveling from front driver side wheel. It is a metal metal clonking noise. It happens only turning right. No sound if straight. I have not taken to my dealer yet but like to hear if anyone found the problem. I won't want my dealer rip me off by changing all components.
CF7
post Jul 1 2008, 09:54 AM
Forgot to mention mine is 2006 Sonata 2.4L
rallyman
post Jul 1 2008, 07:13 PM
See my post above, #4. If that sounds like your problem, I may be able to help as the dealer just figured it out.
They had a few cars with the same problem I was having and it turned out to be the front brake pads. They said there was a new or improved part put out by Hyundai at some time and it corrected the issue. I just had the front brake pads replaced under warranty yesterday and the noise is gone.
ddix1026
post Jul 1 2008, 07:22 PM
Post #11
Lonely Commuter
im guessing a good set of after-market pads would do the trick just as well...
rallyman
post Jul 2 2008, 09:00 AM
Post #12
More than likely but they wouldn't be free!
ddix1026
post Jul 2 2008, 09:31 AM
Post #13
Lonely Commuter
true, but OEM's also wont necessarily be as good either... :grin:
yeah, im biased towards ceramics.. LOL
No New Posts Sonata Cat Back Exhaust
2 hugamuto 65 Yesterday, 04:02 PM
Last post by: hugamuto
No New Posts Sonata Vs. Shopping Cart
12 bakshi6 207 30th November 2008 - 12:04 AM
Last post by: pezhead
No new 2006 Hyundai Sonata 3.3l V6 - Paint Peeling Problems?
need input about buying a hyundai
26 ande1352 354 28th November 2008 - 11:09 AM
Last post by: MsSonataLuvr
No New Posts 2006 Sonata 6-disc Radio
0 Shaun_GST 3 25th November 2008 - 08:16 AM
Last post by: Shaun_GST
No new Sonata Vs M3, 350z And G35
33 v33sonata 445 24th November 2008 - 02:08 AM
Last post by: V6 Sonata
3rd December 2008 - 12:00 AM
