Hi All
The engine in my trajet made a wzzzzzzz type of sound two months ago .the sound comes from the right side behind the front wheel . It is related to the engine speed . obviously , I considered the timing components are the cause . when opened the timing belt cover ,I found out the source of sound comes from exactly the timing belt B tensioner pulley . I used a piece hose to pin point source of sound .
I replaced the suspected pulley . but unfortunately the sound is still there . Is it the oil pump . when the engine stops for two days the sound disappears for the first 20 seconds of operation , then comes back again .
this sound seems to be common , because I heard it from a passing by sonata a few days a go .
Nothing rotates there except the right counter balance Shaft , the oil pump gears and the tensioner B pulley Which is excluded . My engine has clocked 150 k .
Any assistance is appreciated .
