QUOTE(Schwitzer Turbo)
You get the Base model, the LS then the GT.
What is the MAX speed on your Speedo cluster? 220kph?
Does it say turbo on your intake manifold?
If you have a Base model look were the scoupe turbo gauge sit's Does it look like one could be inserted?
The Base is Blank
the LS has a Insert for it
the GT has it.
Does your car have a spot light switch?
130 mph cluster, insert in the dash but no LEDs, basic ECFI Manifold, no foglight switch. So, plausible LS now.. Interesting. But why certain parts (ex. turbo's Fuel filter) fit? I'm not arguing, just genuinely curious, you see. :thumbsup:
And finally the dumb question: What all would I need to turn her into a Turbo model? I'd imaging that different injectors, the turbo flange, ECU changed and a lot of tubing. Anything else? And thank you all for your assistance. :)
Cheers,
Jetboy
