You fill up the reservoir or the radiator itself? The reservoir pulls extra coolant as needed for the radiator, so if it was a little low when you filled it up it will need to pull more in until it's full. If you're needing to refill the radiator itself, then you must have a significant leak somewhere, in which case you should start the car and warm it up until the coolant starts to circulate (upper radiator hose will get hot) and look for leaks from the radiator, hoses, clamps, around the thermostat, etc.
