| 96lantra |
Jun 12 2008, 01:17 PM
Drives: 1996 Hyundai Elantra 1.8L Status: OFFLINE
I can't figure out what's wrong with this car, about 3 weeks ago it started to run very badly so I had everything tested and cylinders 1 3 and 4 misfired, so I changed the plugs and wires with bosch platinum plugs, and cylinder 3 still misfired then it started surging on acceleration like it was kicking in and out of gear and it would stall every now and then, so I changed the coil pack, fired it up and check engine shut off, ran it for about 5 miles and it ran like a champ. Parked it then went to work the next day on my way home the check engine light started flashing again and it started to surge again. so I disconnected the negative battery cable for a couple hours, put it back on and fired it up the check engine light went off and it ran good for about 10 minutes then did the same thing again. I have no idea what's wrong with it please help.
It's a 1996 Elantra 1.8L automatic.
Thank you!
| 96lantra |
Jun 12 2008, 11:22 PM
I already said I got it tested and cyl 3 still misfires
| 96lantra |
Jun 17 2008, 01:05 PM
The only code the tester brings up is cyl 3 misfire, sorry this took a while to reply.
| 96lantra |
Jun 17 2008, 11:26 PM
Yeah a guy ran a compression test on it for me and he said it was good, he said it might be a flat cam but you would hear that wouldn't you? then someone else told me it might be the valve or the valve spring, since cylinders 1, 3 and 4 were misfiring before I changed the plugs and wires, I took the old spark plug and wire from cylinder 2 and put it on the 3rd cylinder to see if the new wire was bad but it still misfired. I'm just shooting in the dark here
| 96lantra |
Jun 19 2008, 11:50 PM
pulled the valve cover, cams are good, springs are good, everythings in place, no visible damage. I've seen a few Hondas do the same thing before and it's usually the fuel pressure regulator. so I'm gonna check that and the injector.
| bah200018 |
Jun 20 2008, 04:34 AM
Drives: 1997 elantra es 1.8 Status: OFFLINE
is there a real bad odor emiited by the vehicle?
| 96lantra |
Jun 21 2008, 11:28 PM
No, no antifreeze smell, no white smoke nothin' like that so it can't be the head gasket, I've had a head gasket go on me in a 91 eclipse so I know what it does when that goes bad
Track this topic
Subscribe to this forum
Download / Print this Topic
Link To Us
Similar Threads
Similar Threads
29th August 2008 - 04:02 PM |
