Gas In South Florida, Alcohol in gas |
Jun 11 2008, 01:00 PM
VALUED MEMBER
Status:
QUOTE(Blue07 @ Jun 11 2008, 09:51 AM) Ethanol contains less power. (It is a slow burning alcohol.) According to Wiki, the energy density for ethanol is 23.5 megajoules per liter compared to 34.8 MJ/L for gasoline. (Gasoline has 48% more energy.) A 10% ethanol blend has an energy density of 33.7 MJ/L and contains only 97% as much energy as 100% gasoline, which causes both power and mileage to drop. [right][snapback]168485[/snapback][/right]
E 85 is 105 Octane. According to the Ethanol Industry and a different Wiki page, an Ethanol blend produces higher octane. I don't know how that translates into power though? *OK Wiki says more Octane equals more Power! http://en.wikipedia.org/wiki/Octane_rating
This post has been edited by MiamiLX: Jun 11 2008, 01:11 PM
Jun 11 2008, 01:06 PM
Status:
Drives: 07 Sonata GLS, 07 Cobalt 93 Jeep Grand Cherokee
QUOTE(Blue07 @ Jun 11 2008, 12:51 PM) A 10% ethanol blend has an energy density of 33.7 MJ/L and contains only 97% as much energy as 100% gasoline, which causes both power and mileage to drop. [right][snapback]168485[/snapback][/right]
Exactly, For years I did a lot of tuning with ethanol. In the real world your #s are about spot on. For every 10% addition of ethanol, your real world mileage should drop 3%. Our testing over a 20 year period has shown this to be very close. Usually it'll come out a bit more like 4%, on average.
Jun 11 2008, 01:21 PM
Status:
I’m not an expert in this area, but…..
Octane describes a fuel’s resistance to pre-detonation. That’s all. Generally that means it burns slowly. To make premium fuel, somewhere in the process, they add “additives” to make it burn slower. The energy density remains about the same. Premium and regular fuel have the same power (99.9%). Regular fuel just burns faster and can ping more easily.
However alcohol is different than gasoline. When it burns, it doesn’t release as much power. Alcohol naturally burns slower and when combined with it’s flash point, is very resistant to pre-detonation. That’s why E85 has a 105 octane rating.
Jun 11 2008, 01:46 PM
Status:
QUOTE(MiamiLX @ Jun 11 2008, 02:00 PM) *OK Wiki says more Octane equals more Power! http://en.wikipedia.org/wiki/Octane_rating[right][snapback]168490[/snapback][/right] I could definitely be wrong, but I didn’t read that when I read the Wiki text. I did read that higher octane fuel had a higher activation energy. “Higher octane ratings correlate to higher activation energies. Activation energy is the amount of energy necessary to start a chemical reaction. Since higher octane fuels have higher activation energies, it is less likely that a given compression will cause knocking.” But I’m still 99% sure that higher octane does mean more power. The only line I found in that Wiki text that dicusssed octane and power was, “It should be noted that octane rating does not relate to the energy content of the fuel.”
Jun 11 2008, 02:01 PM
Status:
Drives: '06 S'nota V6 GLS (Goes Like Snot!)
QUOTE(craigbrooks @ Jun 11 2008, 11:45 AM) Great Falls, MT :thumbsup: See ya soon! :grin: [right][snapback]168504[/snapback][/right]
If you're hitting Great Falls, just remember that there are a lot of cowboys there, who only wear chaps with the cheek parts cut out!!!!! So, you see a lot of Mr. Harry Bum there. I think they're close to Brokeback, as well..............
This post has been edited by Tommer: Jun 11 2008, 02:02 PM
Jun 11 2008, 02:14 PM
Lonely Commuter
Status:
QUOTE(Tommer @ Jun 11 2008, 03:01 PM) If you're hitting Great Falls, just remember that there are a lot of cowboys there, who only wear chaps with the cheek parts cut out!!!!! So, you see a lot of Mr. Harry Bum there.
I think they're close to Brokeback, as well.............. [right][snapback]168511[/snapback][/right]
......says the fella from Cranbrook, BC... (where?) :grin:
Jun 11 2008, 02:25 PM
