> Oil In The Surge Tank / On Map Sensor
gnicholls7
post Jun 9 2008, 07:19 PM
Drives: 2003 Elantra GT, 2001 Accent 1.6L
My 2001 Accent GSI has had a slight bog/hesitation when accelerating at low revs or under high load for some time. In the last two days, the problem has worsened to the point that the car idles roughly, and feels like it is running on 3 cylinders in the lower end of the rev range. Also, it is now displaying a flashing check engine light. The poor running has coinsided with a dramatic increase in temperature in my area.
I pulled the MAP sensor, and found that it was covered in a film of oil. Also, there was a noticable puddle of oil in the opening in the intake surge tank where the MAP sensor plugs in. I imagine that this is likely a case of a bad PCV valve allowing oil up into the surge tank?
Could the oil on the MAP sensor be the cause of the uneven running? If so, will this necessitate replacement of the MAP sensor, or is there a method of cleaning it?
As an aside, I checked all four plugs, and number 4 (far right when facing the engine) seems to have more carbon/residue build up than the other 3. I have yet to obtain the codes from the ECU, but I imagine that several will have been tripped by the uneven idle and revving.
Krzysd
post Jun 9 2008, 10:15 PM
Drives: 2001 Hyundai Accent 1.6L
mine had the same problem i replaced the plugs and wires and set the gap on the plug, and all the hesitation went away. might wanna clean out your intake too, that will help alot.
the oil on the sensor well i dont know what that could be...sorry.
No New Posts The Multifunction Car Dvd Player Cdp0005
1 timusacs 17 Yesterday, 09:16 PM
Last post by: gravelhighway
No New Posts The Genesis Alternative... For Less
21 07 Santa Fe 1,196 1st December 2008 - 08:57 PM
Last post by: 8sonny
No New Posts Instrument Panel Lights
3 rcacs 35 1st December 2008 - 12:33 PM
Last post by: rcacs
No new Topic has attachmentsThe Effects Of Going 100+ Mph In A Sonata
"There has been a fatality. The guy is in half"
102 alex2006sonata 1,381 28th November 2008 - 11:18 PM
Last post by: hugamuto
No New Posts The Horn..
and no.. not how it sounds... hehe
5 Pinto_Siftbean 91 27th November 2008 - 09:47 PM
Last post by: david-paul-1
3rd December 2008 - 12:10 AM
