:00000732: glalas,
Concur. Your problem is likely the jute pad for the carpet is wet and has mold growing in it.
The correct way to fix this is to pull your entire interior carpet and pad out, lay on a clean driveway in the sun half a day, flip over and dry the other side for half a day. Reinstall.
IF and only if the moist area is small (less than 3 sq ft), you could try raising the carpet and mat in that area, placing dry bath towels above and below the pad, change to fresh towels every couple of hours, finish with a blow dryer.
Use Lysol spray disinfectant to kill the mold smell after the pad and carpet are dry.
Byron
