E3 Spark Pugs For The Sonata!, Badass plugs! |
Jun 8 2008, 02:26 PM
Sonata Perfromance Expert
Status:
Drives: Fastest 3.3L Sonata!
Well as many of you know I a manager for Checkers. aka CSK. A few weeks ago a rep for the new E3 spark plug came in. He was very knowledgeable. As he was doing a crash course in training with me I kinda looked at him and said I dont know...... he said a HP gain of at least 2% and fuel gain of 5%. After the look he said I'll tell ya what. Email me and I will send you a free set of plugs. I was sitting here last week and sent him an email. The plugs came in and I installed them today (see pix). I just took it around the block and HOLY CRAP!!! You know how the car has that crappy down shift from 2nd to 1st. Well I dint believe it but I thought I was in 1st. The car pulls so much harder thru the whole RPM band. There is defiantly a HP increase. I would say closer to 10hp. I can't wait to dyno test iit! I am interested in seeing it the MPG goes up. I will let you guys know. *Note changing the plugs the v6 sonata is a pain in the ****!!! the intake manifold needs to come off and there are alot of wires and vacuum lines! I am really amazed! here is the website! Any questions let me know. http://www.e3sparkplugs.com/catalog.htm(IMG: http://i244.photobucket.com/albums/gg1/v33sonata/e3.gif) (IMG: http://i244.photobucket.com/albums/gg1/v33sonata/sparkplugE3.jpg) (IMG: http://i244.photobucket.com/albums/gg1/v33sonata/DSC02158.jpg) (IMG: http://i244.photobucket.com/albums/gg1/v33sonata/DSC02157.jpg)
This post has been edited by v33sonata: Jun 8 2008, 02:32 PM
Jun 8 2008, 04:04 PM
Status:
For $6 a plug, you really can’t get hurt. For giggles, the Pulstars I mentioned earlier cost about $25 per plug. http://www.pulstarpulseplugs.com/default.asp?KID=3340(They are supposed to produce 1,000,000 watts of power compared to 50 watts for a normal plug. Its got to be some trick, or compression of time.) People also claim great gains in mileage, but I suspect they were just due for a normal plug replacement. I’m happy to hear you like these E3s. Keep us posted. Thanks.
Jun 8 2008, 04:39 PM
Status:
Drives: 2007 Hyundai Sonata SE 3.3
At first when I saw the post, I was like, o great the spammers have hit this board. Then I see its V33 and it mentioned the 1-2 shift (most spam ad aren't that specific), and I was relieved. But back to my point, I'm skeptical that those work, the mind can play a lot of tricks. But I do hope that they work. Lord knows that we are unloved by the aftermarket. You should definitely get a dyno run in. If these work, then imagine also doing an intake, and maybe some mufflers; that sounds like an awesome low-buck buildup. I hope to hit the strip sometime this summer so I might just do it. Maybe you've already done that build-up; I can't remember everyones mods. :P
Best of luck to you
Jun 8 2008, 09:04 PM
Status:
I've been considering a set of NGK's; their top of the line series is known as the "Iridium IX" The part # for the v6 is "BKR5EIX-11" I found a set (6) here for $45, double check that just to be sure. As F.Y.I; I had to put 2006 as the model year, the later years don't yield any results. If the plugs gain performance it would be nice, a few ponies for $45 ain't bad.
Jun 8 2008, 11:13 PM
Status:
QUOTE(oceanax13 @ Jun 8 2008, 09:04 PM) I've been considering a set of NGK's; their top of the line series is known as the "Iridium IX" The part # for the v6 is "BKR5EIX-11" I found a set (6) here for $45, double check that just to be sure. As F.Y.I; I had to put 2006 as the model year, the later years don't yield any results. If the plugs gain performance it would be nice, a few ponies for $45 ain't bad. [right][snapback]167639[/snapback][/right] Those NGK's are the same as the car came with stock.
