Timing Belt Change And 180000km Service 2002 V6, Timing belt on a V6
| byronguidry3732 |
Jun 10 2008, 03:41 PM
Group: Super Mod
Drives: 2003 Tiburon GT 2.7, 2004 Santa FE FWD 2.7, 2001 Sonata 2.4, 2000 Elantra, 1984 Pontiac Fiero SE Status: ONLINE
Dear hdsit,
In the US, most mechanics have a reference book listing the hours to charge for the different removal and installation repairs on every car in the model line for a dealer. This is called 'book time'. Most mechanics can meet or exceed the book time for a repair, but this is the traditional cost standard that is used.
I think the book time for your timing belt change in the US is 2.25 hours.
Can your mechanic provide a detailed invoice for the charges? this will show the hours charged for the timing belt, brakes, engine oil, cabin filter, etc. A detailed invoice will also show the costs for the parts. The cabin filter is expensive, as it costs much more than the timing belt.
Byron
| hdsit |
Jun 10 2008, 03:58 PM
Drives: Sonata V6 GLS Status: OFFLINE
QUOTE(byronguidry3732 @ Jun 10 2008, 10:41 PM) Dear hdsit, In the US, most mechanics have a reference book listing the hours to charge for the different removal and installation repairs on every car in the model line for a dealer. This is called 'book time'. Most mechanics can meet or exceed the book time for a repair, but this is the traditional cost standard that is used. I think the book time for your timing belt change in the US is 2.25 hours. Can your mechanic provide a detailed invoice for the charges? this will show the hours charged for the timing belt, brakes, engine oil, cabin filter, etc. A detailed invoice will also show the costs for the parts. The cabin filter is expensive, as it costs much more than the timing belt. Byron Well - as mentioned - it was both a reduced 180000 km service (- spark plugs change and air-filter) it should be max 2 hours, more likely 1 hour - and as far as i can see they want to charge me to approx 7 hours for changing the timing belt, that is rated for 2.25 hours... - Well i get the point...
| vhercules |
Jul 10 2008, 01:59 PM
Drives: 2002 Sonata Status: OFFLINE
I recently had my timing belt changed on my 02 4 cyl Sonata and had to do the following as well --
Flush brake fluid, service brakes, replace timing tensioner belt, replace balance shaft belt, AC belt, power steering belt.
All this came to $1200 for around 4-5 hrs of work.
| sim_e_on |
Aug 20 2008, 09:32 PM
Drives: 2002 Hyndai Sonata Status: OFFLINE
QUOTE(hdsit @ Jun 7 2008, 12:33 PM) Had my timing belt changed and 180000km serviced at the same time. - also changed 2 tensioners Brakes disassembled and greased, ventilatorbelt changed cabinfilter - 2 Pcs??? - as far as i know there is only one... Engine oil and filter changed. Sparks not changed, neither air-filter (uses k&n) 9 hours in labour - it seems like they have added, hmm... some extra hours, as far as i can see. How long time should it take? Ordinary service - max 2 hours Timing belt ? It cost me approx 1900$ Anyone knows. I had my timing belt changed on my 02 4 cyl Sonata about a year ago. They also replaced timing tensioner belt and balance shaft belt, also new coolant and water pump (standard procedure). It took them no more than 3 - 3.5 hours and I payed around $600 for the parts and labour.
Track this topic
Subscribe to this forum
Download / Print this Topic
Link To Us
Similar Threads
Similar Threads
7th September 2008 - 11:52 AM |
