 Hyundai-Forums.com > Hyundai Models > Sonata Forum > 1G-3G (1989-2005) Sonata > Transmission Shifting ?
71mopar383
post Jun 5 2008, 08:14 PM
Drives: 2001 Sonata 4 banger
Status: OFFLINE
My 01 Sonata v-6 when it upshifts it will attempt to make the shift pause then stay in its current gear for another 3-500 rpm then make the shift. It pauses long enough the first time it did it I thought it died. And it doesnt matter what gear its shifting into. But it never throws a code. The car just turned 60k and had the Tranny flushed at the dealership @ 46K :3gears:
This post has been edited by 71mopar383: Jun 5 2008, 08:28 PM
User is offlineProfile CardPM
QuoteReply
itskeiser
post Jun 6 2008, 09:22 AM
Drives: 00 Ford Focus, 01 Hyundai Sonata
Status: OFFLINE
sounds like you're runnin into the headache many of us know
its possible its one of the speed sensors or the tps,all of which are easy to replace and generally can be found online for under 150bucks
QuoteReply
Jam.Audio
post Jun 9 2008, 03:42 PM
Drives: 03 Hyundai Sonata
Status: OFFLINE
definately sounds like the problem
QuoteReply
Aussie98sonata
post Jul 15 2008, 07:56 AM
Drives: 98 EF sonata (2litre)
Status: OFFLINE
Hi, just thought i'd put in my 2 cents worth on automatic shifting problems with the sonata (EF-A model). I recently had both Input and output speed sensors go bad. The output speed sensor went first and would fail after the car warmed up. The usual symptom was bad 1-2nd shifts followed soon after by limp mode (stuck in 3rd). The bad shift is like it goes into nuetral and revs high between gears, like a bad manual gear change. Restarting the car will fix it for a minute or so. Soon after the input sensor went, these symptoms were more serious high idle, thumps into gear when coming to a stop and very poor gear changes. Combine the two and its lots of fun. I picked up new sensors from a 2000 model sonata at the wreckers these appeared slightly different with a continuous barrel on the end rather than small diameter cylinder sticking out of a larger diameter cylinder holding the o-ring.
Changing the sensors is dead easy, although make sure you remove the battery to get at the last of the bolts holding the air box in (added benefit is that the computer then needs to relearn shifting).
You will need a socket set or extensions to get at some of the bolts. BTW the output speed sensor is the more outboard of the sensors on top of the trans casing, the input speed sensor is almost directly under the end of the engine.
Changing them fixed all the problems and cost me only $15.
Hope this helps someone, Jim
QuoteReply
71mopar383
post Aug 29 2008, 11:30 PM
Status: OFFLINE
So I changed the input and output sensors and still it pauses and you think its going to upshift and it stays in the same gear. It looks and feels like a stick shift and you have it say in 1st gear and you get on it then let off then get on it again and you get that jerk feeling that what i have. what next a TPS? or should I try and get a rebuild before my 10/100000 warr is up? :beer:
QuoteReply
> Link To Us
> Similar Threads
2002 Santa Fe Transmission Leak At Cooling Line
DetJoeF 4 0 Yesterday, 09:08 PM
By: DetJoeF
Transmission Drain & Fill
Forum : 4G (2006+) Sonata
John_ 200 12 Yesterday, 06:52 AM
By: Sequoiasoon
Problem With Shifting To Neutral?
Forum : 4G (2007+) Elantra
Osaka 23 0 Oct 8 2008, 07:23 PM
By: Osaka
Transmission Problem
Forum : 1G-3G (1989-2005) Sonata
jaek707 56 3 Oct 8 2008, 04:18 PM
By: theiceage05
Transmission
duggar62 59 0 Oct 7 2008, 03:54 PM
By: duggar62
11th October 2008 - 01:05 AM
