Drawbacks With Azera, Suspension and Dimming Headlights
| hossfly |
Jun 10 2008, 01:36 AM
Drives: 2006 Azera Limited 3.8, 2007 Sonata GLS 2.4 Status: OFFLINE
heypal...I understand your frustration with the struts and the dimming of the headlights. My 06 Azera has been at the local dealer on both these issues twice. They did R&R the Rt Frt Strut and R&R the Alternator (Generator as Hyundai calls it) do to possible diode issues with the Alternator. The Battery and all charging aspects have been double checked, but the dimming continues. Yes the dimming is a safety hazard and causes issues with other drivers at night as you have stated. I'm currently engaged with Hyundai on this issue. I was wondering if you have had any positive results from Hyundai? I'm filing a complaint with the NHTSA on there website for Recalls and Defects (http://www-odi.nhtsa.dot.gov/ivoq/) under the safety issue with the headlight dimming. Might suggest you do the same and others to affect some impact with numbers of complaints. Please inform if you have any further positive news.
| snaglepus |
Jun 21 2008, 07:22 PM
Drives: 2007 Azera SE Limited built 12-12-2006 and 'Old Faithful', our Kona Focus Status: ONLINE
:) Hey . . . heypalToday is indeed your lucky day! See: http://www.hyundaitechinfo.com/Noteably TSB 08-BE-0046/17/2008 [all] 08-BE-004 DIAGNOSIS VOLTAGE DROP I think perhaps your prayers may have been answered! :amen: The fix is so simple; I cannot understand why someone has not discovered it before. :w00t: Now, if only the same would occur on those floppy front shocks. :whistling: :57: This post has been edited by snaglepus: Jun 21 2008, 07:23 PM
| andyman32 |
Jun 21 2008, 08:56 PM
Expert
Drives: 07 Azera Ultimate #1, 07 Azera Ultimate #2, 96 Vanden Plas, 97 XJR Status: OFFLINE
Hate to say it, but the Jags get the same thing. Exact same thing. Dimming headlights when coming to a stop (alternator spinning more slowly), when operating the window motors, or other high-current operations. Of course it won't happen until a few years, 5-8, not when the car is brand new. Checking electrical grounds is standard fare.
We can fault Hyundai here for either substandard quality on the original nuts & washers for the electrical grounds, or loose ground connections.
But you can also just scrub up most of the vehicle's ground connections with a wire brush and tighten them up in about 10 min, 15 min. if you're nursing a beer. ;)
:beer:
| snaglepus |
Jun 22 2008, 01:45 PM
QUOTE(heypal @ Jun 22 2008, 09:33 AM) Snaglepus, Interesting name there. Thanks for the information on the light problem. I just went to the dealer last week to get my oil changed. I told the service guy about the diming problem but of couse they can't find anything because it happens when the lights are on at night and the car needs to be driven at night. Just sitting there on idle it never happens. The TBS didn't do anything for me at the dealer on the suspension as they couldn't hear any problems. Yea right. So we will see if they will do anything about the lights. I must say I see this problem every night when I get off work and oncomming cars continue to flash their headlights at me. Try another dealer. Many of us have gotten the dealers to change the shocks out per the TSB even though we do not have the noise! But that 'fix' only lasts a short while, and then the worn out shock feeling returns same as with the older original shocks. Many who have had the noise problem are reporting that the noisy "clunk" is still there after the TSB was done. Copy both the TSBs for the shocks as well as the newest one for your lights going dim. Have you read that TSB? Please do, as it describes in detail what the tech must do to test for the problem. Just because it is daylight does not mean it will not happen. Anyone with a volt/omometer will be able to see what's happening, especially when the engine idle speed is at an idle and all those electrical useages are turned on. Doesn't matter whether it is dark or daylight. Go luck. You do know how to get to the site that has the TSBs I trust? Regards, Snaglepus.This post has been edited by snaglepus: Jun 22 2008, 01:46 PM
| joezera |
Jun 22 2008, 02:18 PM
Drives: '07Azera Ltd, Premium, 3.8L V6; Dodge Ram 5.9L I-6 Status: OFFLINE
snaglepus wrote: QUOTE Copy both the TSBs for the shocks as well as the newest one for your lights going dim. Have you read that TSB? Please do, as it describes in detail what the tech must do to test for the problem. Just because it is daylight does not mean it will not happen. Anyone with a volt/omometer will be able to see what's happening, especially when the engine idle speed is at an idle and all those electrical useages are turned on. Doesn't matter whether it is dark or daylight. Right on! I have also seen cars develop dimming lights (more noticeable at night when in Drive and with AC etc. on). Sometimes it can be corrosion or a poor crimp inside an end terminal of an electrical cable. In those cases you cannot see any apparent problem, but replacing the defective wire (usually will show up as a high resistance with an ohm meter) will correct that type problem. More often, paint acting as an insulator or corroded connection points with the body sheet metal and/or frame are the culprits. A service technician with good training and experience should be able to find and correct the problem. If the service department at a given dealership can not find the problem, I would try another dealership. Good luck! :) Joe
| snaglepus |
Jun 23 2008, 10:40 AM
QUOTE(heypal @ Jun 23 2008, 04:24 AM) Snaglepus, Do you in fact or anyone else here have the dimming headlight problem? I [have] seen the TBS and when I get some time next month I will make it a point to visit the dealer where I purchased the Azera and if nothing happens there another Azera dealer is only a few miles away from my home. LPH :) Many have complained and have been complaining now for some time. When I first saw these complaints, I was surprised that all were saying that the techs at their dealers could not correct this problem! Well you must know that because of these many complains, the corporate people have finally issued a TSB on this problem. What is says is only common sense that any knowledgeable mechanic should know to do without being so instructed by a TSB. Notice the word knowledgeable. That lets many mechanics out, for if there are not a set of specific instructions as to what to do to correct a problem, they are simply lost! Take yours in and point that recent TSB out to your friendly service salesman. I will bet that he has never heard of it! :P Good luck. :amen: This post has been edited by snaglepus: Jun 23 2008, 10:44 AM
Track this topic
Subscribe to this forum
Download / Print this Topic
Link To Us
Similar Threads
Similar Threads
29th August 2008 - 01:02 AM |
