> 2000 Accent Speedo Reads Out Incorrectly?, Is it just a Hyundai thing???
NK777
post Jun 3 2008, 10:25 PM
Drives: 2000 Accent 1.5L 5sp
So I just bought a 2000 Accent 2dr coupe 5sp. Seems to me after following my wife around in her car that the speedo is way off. It seems to indicate 55 mph when traveling at 50 mph. And before you ask yes it has the factory 175/70R13 tires on it. I don't understand this since it is an analog speedo that uses a cable and gear setup correct? Only thing I can figure is somebody swapped out the speedo gear? But see that doesn't make a lick of sense either because the vehicle is completely unmodified. Any help on this matter would be great.
Thanks,
NK777
gbajosh
post Jun 4 2008, 03:09 PM
Drives: 02 accent
with my 02 accent once in a while it's of by 1-5 mph, not rlly a big deal. everything with hyundai is off.
I check mine with the speed checks the cops setup.
Aussie Steve
post Jun 5 2008, 07:49 AM
Drives: Hyundai Accent 2001 3 dr...engine size 1.5 litres, fully standard, no CD player, just a radio/cassette...
I wouldnt think that's way off, speedos- particularly the analog type- are notoriously unreliable and can be off by maybe 8 percent or more...I wouldnt worry about it...could be your wife's car is a few mph off too, how can you be sure hers is accurate ? just asking dude ;-))
NK777
post Jun 7 2008, 11:06 AM
Okay I know the wife speedo is correct because it's a digital speedo on a dodge durango and I have personally checked it with my gps and it is perfectly accurate. I have now checked the Accent with the GPS and I find that it is indeed almost 8% off. I decided to correct for this some what by running taller tires 185/70 R13. Now I am only around 5% off which is a whole lot better.
Why does this bug me you ask? Because you are wrong, most manufacturers I have experienced do indeed provide you with a decent speedometer (Ford, Dodge, Toyota's that I have personal experience with). All of my other cars in the past have also had analog speedo's as well. The wifes Durango is the only vehicle I've owned with a digital speedometer. An anolog speedometer that is inflated by 8% will also add 8% to the odometer thus skewing the mpg numbers. I just personally think thats BS to mislead your customers. Mind you I find that the Accent still gets decent mpg but 8% really does skew your results when calculating mpg. For example I calculated 35mpg last fill up using the actual odometer reading (260 miles) and the 7.37 gallons I put in the tank. This works out to roughly 35 mpg but when you correct for this 8% error you will find that your actual mpg is 32.25 mpg. Yes I do believe Hyundai did this intentionally and yes I do believe it's BS. See it just isn't that hard to put the correct tooth speedo gear on your speedo cable to make it more accurate, no it probably won't be perfectly accurate but it would be far more accurate if they simply put in a speedo gear that had one more tooth. Trust me I do know what I'm talking about here. I've built many 4x4 trucks and had to correct allot of speedometers due to running much larger tires.
gbajosh
post Jun 8 2008, 11:02 AM
Drives: 02 accent
it's a cheap little hyundai.
you're lucky it starts
31 PastorK 881 1st December 2008 - 08:45 PM
Last post by: PastorK
No New Posts 2000 Lantra Electrical..
4 cokaznrebel 30 30th November 2008 - 03:03 AM
Last post by: cokaznrebel
No New Posts Topic has attachmentsAccent Vs. Deer
The deer was at a handicap...
9 blazianenigma 137 29th November 2008 - 12:58 AM
Last post by: hyunnychub
No New Posts 2000 Tiburon Trouble Code
1 Tiburonjoe 9 19th November 2008 - 11:16 PM
Last post by: byronguidry3732
No New Posts 2000 Sonata V6 Rear Brake Problem
2 surfboarder 22 17th November 2008 - 05:23 PM
3rd December 2008 - 12:24 AM
