I purchased a 2008 Santa Fe SE AWD and added the towing hitch option only, per the recommendation of the sales rep and another sales rep who sells a lot of trucks.
We have a 19' Crowline boat that I believe is around 3,000 lbs total weight.
We wanted to purchase the towing package that has the additional trans. cooler, radiator, fans, etc., but did NOT purchase that because those options would also add a 3rd row of seats (that we didn't need), and reduce the storage room (that we DID need)! So we only added the towing hitch.
We plan to pull the boat less than 10 miles to the Missisippi River (each way) a couple of times a month to go boating. The first time we did this, everything went just fine, and the Santa Fe pulls the boat to and back out of the water with apparant ease!
However, I noticed what I would call a 'hot oil' smell coming from the Santa Fe when we put the boat back into the garage, so I am afraid of twing the boat again until I check with the experts on the Hyundai Forum !
Will I be causing a problem to the vehicle because I have the 'tow hitch' only and I do not have the additional 'towing package' engine components ?
When do you need the other components? Longer distance towing? Heavier towing ? Towing in hot weather?
Is the 'hot oil' smell legit, or am I over-reacting?
Will our Santa Fe be okay with just the tow hitch ?
What are my options if it is not ok to have the hitch only?
Please advise !
Thank You !
You most likely have the "towing package" already. I saw on my window sticker that it said towing packing included. I looked at all the 3.3 l on the lot and they all had the towing package.
Vehicle Model Year Receiver Size (Inches) Towing Capacity - kg/lbs Tongue Weight - kg/lbs
