QUOTE(Doohickie @ Jun 2 2008, 02:26 PM)
If the non-dealership place used anything other than SP-III fluid in your transmission, you may have already killed it. Many "universal" AT fluids have detergents that damage the materials in Hyundai transmissions.
If you problem is not the transmission itself, I suspect a bad Intake Air Controller or Throttle Position Sensor.
I will f-up with the garage I went to. I was having the problem even before the transmission flush though.
Can the non-Hyundai guys replace an Intake Air Controller or TPS?
Are these relatively expensive?
Any problem replacing these even if nothing is wrong with them?
