QUOTE(RetsaM @ Jun 4 2008, 12:39 PM)
maybe because you don't explain you problem correctly...
How much is a bit for you?
Where it is leaking?
If it is from the block ... good luck you need to go (probably) see a machinist to flated the head...
My head gasket is leaking ... but not coolant, motor oil... It's a easy fix...
but if your head gasket is leaking coolant.. good luck...
But don't be an as$ h0le, we are all busy.
and some look only the weekend.
Regards,
Jonathan Lévesque
Qc, Canada
[right][snapback]166596[/snapback][/right]
Jon
"... It's a easy fix..." how so? Easy, really. What would it entail?
-tr
