QUOTE(jsharptooth91 @ Jun 3 2008, 04:36 PM)
I put led tail lights in my accent. They worked until I tried to use my blinker. They just stayed on. Led tail lights didnt work for me, I assume you will have the same issue. You could always change the resistance of the circuit, and that may work.
The thing that I have had to do in one other vehicle that I own when going to LEDs was install an electronic flasher. As you stated the LEDs have lower resistance and cause the flashers not to flash.
You can get the electronic flasher at all parts stores.
