 Hyundai-Forums.com > Hyundai Models > Elantra & Lantra Forum > 3G (2001-2006) Elantra
> Elantra Gt 5 Speed 2003, Second gear grind when down shifting
loverofsugar
post May 30 2008, 05:02 AM
Drives: hyundai elantra
The problem I am having is when ever I try to downshift into second gear while going over 27mph+ the gear will intermittently grind, but it will still go in easily. This is with the clutch to the floor. The same thing happens when I try to double clutch in to second. When shifting from 1st to second gear the transmission works just fine every time. This just started about a month ago, and up until that time I had never grinded a gear in this car once. Normally this grind will only happen once every few days, but going around corners while braking and downshifting into second will cause it to grind every time regardless of speed. 1 3 4 5 and reverse all work properly. I just had the clutch, timing belt, transmission and clutch fluid replaced in March of this year. 86,000 miles are on the car now and about %70 of it is hwy miles.
Any ideas as to the problem or cost to fix?
This post has been edited by loverofsugar: May 30 2008, 05:07 AM
loverofsugar
post Jun 9 2008, 05:12 AM
The transmission fluid is the answer. If you have this problem, a common one you just need to upgrade to a more expensive transmission fluid. I'm using Mobil 1. The day I got the new fluid my second gear worked properly.
01-06 Elantra manual transmission use 75w90 oil
-add to old post-
By "answer" I meant to keep my second gear from going out for the next 10 to 20,000 miles. The synchronizers in the manual transmission are known for going out due to a lack of lube. The more expensive transmission fluids have a better viscosity so they will reduce or eliminate the damage.
This post has been edited by loverofsugar: Jul 9 2008, 03:32 AM
No New Posts Elantra 2004 Clutch Pedal Noise
clutch pedal noise
0 cachorros 1 Today, 06:24 PM
Last post by: cachorros
No New Posts Topic has attachmentsSpeedometer Off?
13 Pantsonfire 292 10th November 2008 - 09:53 PM
Last post by: v33sonata
No New Posts 2003 Elantra Gls
Horrid Grinding Noise (Front End )
4 David Stahl 250 6th November 2008 - 02:15 PM
Last post by: LilBean
No New Posts 2003 Tib Body Parts
0 BBitz06 9 4th November 2008 - 11:27 PM
Last post by: BBitz06
No New Posts Speedometer Odometer Cruize Controll All Dead
grrrrrr
4 ejfortier 162 21st October 2008 - 11:40 AM
Last post by: ejfortier
2nd December 2008 - 11:58 PM
