> Diy Hyundai Accent Mc Bi-xenon Projectors Retrofit
rondy_
post May 27 2008, 11:58 PM
Drives: 2006 Hyundai Accent
Ok guys, so finally here it is my own write up about the DIY HID projectors retrofit for the MC.
What you need?
- bi-xenon projectors (Inifniti FX) $140
- H4 bi-xenon harness $55
- D2S HID kit (2 ballasts + 2 bulbs) from $80
- Shrouds bezels from $25 (you can make your own bezels)
Tools and material:
- Rotary tool (Dremel)
- Cutting discs for the rotary tool
- Rotozip bits for the rotary tool
- Heat gun
- Black high temp silicone
- Flat blade screw driver or butter knife
- Shop towels
- JB weld
- 8 screws 3 inch long
- Screwdriver for these screws
- 24 nuts at least (3 for each screw sized 6-32 from home depot)
- Electrical tape
First of all take your headlights out of the car. You don’t have to remove the bumper to remove the headlights from the MC.
Now we are working with one headlight at a time. You have to open your headlight. Remove this screw.
(IMG:http://memimage.cardomain.com/member_images/10/web/2818000-2818999/2818495_53_full.jpg)
With the heat gun in level 1 start heating the headlight in the part where you are will be prying first, for example heat all the upper part.
(IMG:http://memimage.cardomain.com/member_images/10/web/2818000-2818999/2818495_55_full.jpg)
Heat it for a minute or so until the headlight it’s a bit hot to the touch but not too hot. Start prying. The objective is to soften the glue. If the headlight cools down heat it again. It should be easy to pry if it is not easy it is because the glue is not hot enough.
(IMG:http://memimage.cardomain.com/member_images/10/web/2818000-2818999/2818495_57_full.jpg)
Go like this all around the headlight, until it is almost all apart.
(IMG:http://memimage.cardomain.com/member_images/10/web/2818000-2818999/2818495_58_full.jpg)
Heat all around the headlight and then just pull it apart with your hands.
Now that you have the headlight apart you can put aside the housing because you’ll be working with the reflector.
To take off the reflector. Look into the back of the headlight, there are 2 screws, for vertical and horizontal alignment. Back out those all the way the just try to pull off the reflector. If it doesn’t pull off easily the alignment screws aren’t completely loose.
Take out the bulb (if you haven’t). At the back of the reflector you can see two small screws, one holding the clip that holds the bulb and the other holding the thing that covers the bulb from letting you seeing it from the front. After you take out those you should have the reflector ready to retrofit it :).
Now take your bi-xenon projectors. The projectors have the OEM parts to mount it on the headlights there were taken out. You have to trim the projectors to make them smaller with your rotary tool and cut off discs. You just want the projector and not the OEM mounting hardware. There are 4 screws in the projector body that hold the part of the lenses with the part that holds the bulb. Just trim the projector so you can still use these screws. You should know what I mean if you see the projectors, its common sense.
Sorry for the lack of pics guys but I just didn’t take any in this part.
Take out the 4 OEM screws I mentioned in the projector and put 4 screws 3 inch long. And put a nut in each of the screws to hold the projector body together. Put an extra nut in each of the screws (you should have at least 2 nuts in each of the screws right now), just leave the second nut like half way of the screw.
With the 4 long screws see the rear of the projector and measure the distance between each end of the screws. For me, I think it was 9 cm the horizontal distance and 4.5 cm the vertical distance.
With the distance you can make a template that will help you to mark the points where you will be drilling to put the projector on the reflector.
(IMG:http://memimage.cardomain.com/member_images/10/web/2818000-2818999/2818495_100_full.jpg)
rondy_
This is the part where I screwed the first time, and it can be a pita if you have to do it several times.
Try to make the marks so that the center of them it’s also the center of the bulb. To get some pretty straight holes just take as reference the horizontal lines molded in the reflector. This is the best way to know if your holes are straight, those horizontal lines in the reflector are also horizontal in respect to the ground when the headlight it’s mounted on the car. Make sure they are straight otherwise your beam pattern would look weird and you would have to come back to this step. I’m not trying to scare you :P.
Also note that where you’ll be drilling the holes doesn’t go through any of the reflectors mount hardware, if so just move marks just enough so the rotozip bit can go through. Remember if you move one mark you have to move all the marks.
Drill the holes a little bit bigger than the screws of the projector, so you can have playroom to adjust the projector later. Now from the rear of the reflector draw a line from the center of where the bulb was all the way to the top of the reflector. This is to know where the bulb was point at.
Now you have to cut the complete base where you putted the bulb before, it is to make the hole big enough to put the projectors hole in there.
It should look something like this. Note that in this image those holes are not straight so I had to re-do them. Just drill the holes exactly where the horizontal line on the reflector is.
(IMG:http://memimage.cardomain.com/member_images/10/web/2818000-2818999/2818495_101_full.jpg)
This is where the painting should be if you are painting the reflector or something. It is kind of tricky not to screw up the chrome.
Also you may want to make sure the projector is clean from the inside.
Put the projector into the reflector, it should look straight. You can move the projector and you are going to secure it with an extra nut or two in the rear of the reflector.
You should align the projector this way in order that the mounting hardware of the reflector can support the projectors weight.
Seeing the projector and the reflector from the rear, align the center of the projector so that it is slightly to the right in respect to the center of the bulb of the left headlight, or to the left in respect to the center of the bulb of the right headlight. What I mean is that when you are aligning your headlight you want to have the horizontal alignment screw almost all the way in so that the reflectors won’t pull off by itself. When aligning the headlights if you tight the horizontal alignment screw the beam goes outside the center of the car, that’s why you want the projector to be slightly very slightly pointing inwards the center of the car before the alignment comes in place.
This is the left reflector. The green line shows where the old bulb was pointing and the green arrow shows where the projector should be pointing. As you can see this picture was taken before I knew it had to be that way.
(IMG:http://memimage.cardomain.com/member_images/10/web/2818000-2818999/2818495_105_full.jpg)
For the vertical alignment of the projector, you want to have the projector slightly upward.
This picture shows how it should be. The angle of that should be 90 degrees, as you can see the angle in the picture is obviously not 90 but that picture was taken before the right set up came out, so just make sure it is 90 when you are doing it.
(IMG:http://memimage.cardomain.com/member_images/10/web/2818000-2818999/2818495_104_full.jpg)
When you get to align the projector right, secure it with the extra nut I mention to put before in the screws and also secure it with the nuts that you putted in the rear of the reflector, tighten them down a bit, but not too hard. I putted some black silicon in the inside nuts to prevent them from moving.
(IMG:http://memimage.cardomain.com/member_images/10/web/2818000-2818999/2818495_103_full.jpg)
You may need to trim the screws in order to make the reflector fit in the headlight again. Now put the reflector in the headlight tightening the alignment screws like half the way in. Go to your car and align the headlights using the original alignment screws. Also check that you have a horizontal cut off line. If you don’t have a horizontal cut off line or your headlights can’t be adjusted go back to work with the reflector and projector until eventually you get it :P.
(IMG:http://memimage.cardomain.com/member_images/10/web/2818000-2818999/2818495_107_full.jpg)
(IMG:http://memimage.cardomain.com/member_images/10/web/2818000-2818999/2818495_108_full.jpg)
If everything is aligned, take out the reflector of the headlight again and put some JB weld at the back of the housing where the screws are. You may also want to put some JB weld on the inside of the reflector to secure the nuts stronger. Use some electrical tape to cover the hole where the bulb was.
It should look something like this. This is a picture taken before the right one came out. I actually used black silicone instead of JB weld because I got sick of removing JB weld. Black silicone is easier to remove but JB weld is stronger. That’s why I’m telling you to see if headlights can be aligned, if so use JB weld.
(IMG:http://memimage.cardomain.com/member_images/10/web/2818000-2818999/2818495_106_full.jpg)
After the JB weld dries up. Put the projector back and go to the car and align it again. You want to make sure everything is aligned before putting the housing back together.
You may want to cover the projector’s hardware to make it look better and cleaner. You can buy the bezels or you can make your own by cutting some piece of aluminum or something. I just wanted it to look good so I got some angel eyes bezels. When I thought the pita was over, the bezels said NO, you have to trim them to fit the projector.
(IMG:http://memimage.cardomain.com/member_images/10/web/2818000-2818999/2818495_109_full.jpg)
(IMG:http://memimage.cardomain.com/member_images/10/web/2818000-2818999/2818495_110_full.jpg)
These angel eyes don’t light up. Putting some CCFLs will be one of my next mods.
As you can see the bezels don’t cover the projector completely. Maybe it would be nice to paint the projector also to make it stealth with the background. I didn’t do it, but would be nice. With the housing it looks very good anyway.
(IMG:http://memimage.cardomain.com/member_images/10/web/2818000-2818999/2818495_111_full.jpg)
You are done with the retrofit. Clean everything very good. Put back the headlight together and now you are going to seal it. Just as when you were prying, now you are going to press them back together. Heat some part to soften the glue, and push them back, just do this until you seal the housing completely. Now put some black silicon all around just in case there was some imperfect seal. Put some shop towels where the turn signal bulb is, to let them absorb all the moisture that could be trapped. Leave them about 2 or 3 hours. Put the turn signal bulb again. And your almost done!.
(IMG:http://memimage.cardomain.com/member_images/10/web/2818000-2818999/2818495_112_full.jpg)
Put the headlights back into the car. Now just plug n play your HID kit with your bi-xenon H4 harness. Install just like a regular HID kit, the only difference is that you are going to connect the high beam wires from the H4 harness to the bi-xenon projectors and that’s it.
Enjoy!
(IMG:http://memimage.cardomain.com/member_images/10/web/2818000-2818999/2818495_113_full.jpg)
(IMG:http://memimage.cardomain.com/member_images/10/web/2818000-2818999/2818495_114_full.jpg)
(IMG:http://memimage.cardomain.com/member_images/10/web/2818000-2818999/2818495_115_full.jpg)
Video
http://video.cardomain.com/clip.aspx?key=FB3421A6F32F16C9
You can get all the parts at eBay. I got mine from directly from http://www.theretrofitsource.com
This mod can take several days, its better to get another set of headlights, plus if you sell the car you can put the stock headlights and keep the projectors for your next retrofit, lol.
The light improvement is amazing, I had HID kits before and this is far better.
I have 4300K bulbs. I suggest not going more than 6000K because the light gets bluer and it’s not useful. The Kelvin is inversely proportional to the light output. The more K you have the less light you are getting.
This was a long write up. I hope ends up doing this mod too.
Doubts or comments?
:beer: :beer:
rondy_
post May 27 2008, 11:59 PM
Also check this topic
http://www.hyundai-forums.com/t27026-infin...rs-retrofit.htm
suneet_ag
post May 28 2008, 10:55 AM
Drives: 2004 Hyundai Santro Xing(Atoz) XS 1.1, 2008 Hyundai i10 Era 1.0, 2008 Hyundai Verna %
This is awesome dude!!!! Quick question, if the car has electric headlight alignment (I am from India and Indian Accents have one) will it still work with this mod?
suneet_ag
post May 28 2008, 10:58 AM
Did you put the angel eye bezels with screws or stuck them with silicone?
rondy_
post May 28 2008, 04:09 PM
QUOTE(suneet_ag @ May 28 2008, 10:58 AM)
[right][snapback]164679[/snapback][/right]
I used silicone for the bezels.
About the electric alignment. I dont know if it would work. It should work, but there is a problem, the projectors are heavy for the original mounting hardware of the accents headlight. I dont know if the electric alignment can handle them. You should give it a try. Get the smallest and lightest bi-xenon projectors.
rondy_
post May 28 2008, 04:10 PM
Or just disconnect the electric headlight alignment module :P.
suneet_ag
post May 29 2008, 10:49 AM
:amen:
suneet_ag
post May 29 2008, 10:53 AM
Another thought. The inner angular corners of the headlight have space for marker lights. If you can place some LED's in a small black painted aluminium cone ( a little smaller in dia than an ice cream cone) with a suitable lens it'll fill up the empty space and give the headlamp the look of the SR concept.
Worth trying at tleast
rondy_
post May 29 2008, 04:16 PM
Oh yeah, it will give the look of the SR concept. And you could also replace the turn signal with another aluminum cone with lense. It is possible you just need to do it :). Working with the headlight isnt that hard and you can do all what comes to your imagination as long as you have room for it.
I plan on putting some white angel eyes :D.
LePapirrikY
post Aug 17 2008, 12:25 AM
Post #11
Drives: 2006 Kia Rio LX
QUOTE(rondy_ @ May 27 2008, 10:58 PM)
you should use some ABS plastic to cover your projector, you still can see it. buy one and use a heat gun to mold it on the edge of your projector that should it, because you still can see some metal.
just my 2 cents. :57:
This post has been edited by LePapirrikY: Aug 17 2008, 10:45 PM
downhiller88
post Aug 22 2008, 12:48 PM
Post #12
Drives: 2007 Hyundai Sonata GL Premium Package
thats talent!
31 PastorK 881 1st December 2008 - 08:45 PM
Last post by: PastorK
No New Posts Hyundai Does Not Want To Hear From Consumers Or Anybody
22 Carolina Bob 305 1st December 2008 - 02:44 PM
Last post by: snaglepus
No New Posts Hyundai Service Prices
1 gez 22 1st December 2008 - 07:29 AM
Last post by: porky
No New Posts Hyundai Excel/accent '95
fun and games
0 Mulcahy 16 1st December 2008 - 01:21 AM
Last post by: Mulcahy
No new Topic has attachmentsHyundai Azera Reliability
81 mkaresh 6,650 30th November 2008 - 02:22 AM
Last post by: jvrijn
3rd December 2008 - 12:18 AM
