I had to replace my right front tire because it was makeing so much noise. I thought I had a wheel bearing going on my right rear so I moved the tire to the front and the sound went with it. The tire is cupped bad (pre-wreck tire) :grin: Had the car aligned and it was out there for sure. Other three tires are fine........Anyway...... The OEM tires are on sale. I will not put them back on myself once these are gone.
Although the four new ones are working very well on the Toyota. :thumbsup:
Michelin Energy MXV4 Plus
(Grand Touring All-Season)
SPECIAL OFFER: Buy four and get $500 travel discount card.
Overview | Specs | Warranty | Reviews | Test Results | Survey Results
Sidewall Style: Blackwall
Serv. Desc: 98V Load Index 98 = 1653lbs (750kg) per tire
Speed Rating “V” = 149mph (240kph) UTQG: Treadwear: 400
Traction: A
Temperature: A400 A A
Orig. Price: $171.00 (each)
$145.00 Special
Estimated Availability: In Stock
Optional Road Hazard Program: additional $17.40 per tire
http://www.tirerack.com/tires/Compare1.jsp...=All&loadRank=2
