Ok, so the buttons on my dash clock don't appear to work. Does anyone know the right way to set it?
There are 3 buttons - H, M, R. I've tried pressing different combinations of these, along with pressing and holding R while also pressing H & M.
The fuses are fine, and the display works.
(I've checked around and didn't fine the answer, but I did find several people that had the same type of issue and they either pulled the clock out and messed w/ the wires or they unplugged the battery at 12:59, then hooked it back up.)
What is the normal way to set the clock?
Thanks in advance!
