 Hyundai-Forums.com > Hyundai Models > Sonata Forum > 1G-3G (1989-2005) Sonata > 2003 2.7l V6 Hard Start After Refeuling.
Rjtubergen
post May 27 2008, 03:17 AM
Drives: 2003 Sonata 2.7L
Status: OFFLINE
Hi,
I have a 2003 Sonata GLS w/ 2.7L V6.
The last three times I have refeuled, it was hard to get it restarted.
It would start and idle very rough then die. This happened several times. I had to keep the RPMs up so it wouldn't die out on me.
After this initial problem, the car will start and run fine until I have to get gas again.
It only occurs when I refuel...If I'm at home or work, she'll fire up fine. Any thoughts?
TIA
Bob
User is offlineProfile CardPM
QuoteReply
mgg61
post Jun 12 2008, 12:17 PM
Drives: 2004 Sonata
Status: OFFLINE
Bob,
I just start experiencing the same problem. Did you ever find out what the problem was?
QuoteReply
Rjtubergen
post Jun 12 2008, 06:22 PM
Status: OFFLINE
Nope. It's still doing it. ONLY when I refuel. It will start fine until I need to refuel again....
Post here if you find out what it is.
I'm going to try a new gas cap ($7- $8)....
QuoteReply
chinook
post Jun 16 2008, 08:24 PM
Drives: 2003 Hyundai Sanata GLX
Status: OFFLINE
When you fill your tank, do you try to put as much as possible in or do you stop after the first time the hose shuts off?
You may have a check valve in the evaportion system leaking that gets flooded when you top off the tank.
Chris
QuoteReply
byronguidry3732
post Jun 18 2008, 09:59 AM
Group Icon
Group Icon
Group: Super Mod
Status: OFFLINE
Dear rjt,
Concur with Chinook. If your evaporative charcoal canister gets saturated with gasoline, say from consistently overfilling your tank, this can cause a rich start condition...like the symptoms you mentioned.
You did not mention any Check Engine Lights, and normally problems with the charcoal canister will give you a CEL.
Byron
QuoteReply
Yarm
post Jun 21 2008, 09:13 PM
Drives: 2005 TUCSON
Status: OFFLINE
Take it to the dealer and tell them to check the evap system purge valve bet its stuck open ,its on the back of the intake manifold 2 rubber hoses on it an 2 wires ,the evap lines are made of steel and rust flakes inside of the steel lines get in the valve and it sticks open , you should have a check engine light on too ,the new valves have a filter to stop this from happening again ,and don"t over fill the tank with gas ,when this valve is stuck open the gas fumes from the tank are forced from the tank when filling with gas into the engine and cause a flooding condition ,if valve is closed it stops this from happening hope this helps
This post has been edited by Yarm: Jun 21 2008, 09:18 PM
QuoteReply
> Link To Us
> Similar Threads
Engine Cranks But Car Won't Start
davesacre 122 3 Sep 30 2008, 07:34 PM
By: robtemple
Elantra 2003. Difficulty Fuiling
Forum : 3G (2001-2006) Elantra
Pestopinan 79 0 Sep 23 2008, 10:18 PM
By: Pestopinan
Alarm 2003 Elantra
SardisGrandma 185 5 Sep 20 2008, 09:27 PM
By: Doohickie
Hyundai Santa Fe Cold Start Isses
trevorhinton 324 6 Sep 19 2008, 05:03 AM
By: byronguidry3732
Looking To Start A Tiburon Meet In Northern Cali
Forum : GK Tiburon (2003-2008)
rubbermbn 84 0 Sep 17 2008, 05:05 PM
By: rubbermbn
6th October 2008 - 10:09 AM
