> Check Engine Light
Pilot84
post May 22 2008, 03:51 AM
Drives: XG 2001
Hi, the check engine light has come on. what should I be looking to replace? where should I start?
2001 XG
Greywolf
post May 22 2008, 07:47 AM
Drives: Grandeur (XG300) 1999 3.0L
First thing, have you noticed any problems with the car ?
Second, do you have a regular mechanic ? If you do, check if they have access to an OBD-II scanner. It's a machine that can read the diagnostic codes off the ECU in the car and give the mechanic an idea of what's gone wrong.
Let us know what happens next, don't just go replacing stuff at random.
This post has been edited by Greywolf: May 22 2008, 07:47 AM
Pilot84
post May 23 2008, 04:52 AM
Drives: XG 2001
Hey - no haven't felt anything out of the ordinary. He got a fault P0115 Temperature Coolant Malfunction. He cleared the fault and then it came up again when he cleared it so he said there is a problem somewhere there.
He did it free of charge (Auto Masters at Melville - Western Australia). Nice guy.
What would you recommend from here? Hyundai wanted $AUD 115 to diagnose a problem and could only see my car on the 15th June! FFS. Anway, at least I kinda know whats wrong now... what next doc?
Greywolf
post May 23 2008, 02:53 PM
Temp coolant malfunction sounds like the temp sensor connected to the thermostat. Someone correct me if I'm wrong, but this would affect the radiator fan ? When the car reaches operating temperature the fan may not kick in, or may just be running all the time ?
If the fan is running constantly, it's not such a big issue. Reaching operating temperature takes longer, and you do run the risk of sludging the engine if you only do short runs and don't change the oil at regular intervals.
The fan not running is a bigger issue, as you run the risk of overheating in traffic, or at prolonged stops where the radiator has no way of being cooled.
In the big scheme of things it's a pretty insignificant malfunction, why not see what the mechanic at Auto Masters will quote you to replace the sensor ? Or you could have a go yourself, track down a Grandeur being wrecked and hope the sensor out of that is a-ok.
se4mus
post May 23 2008, 04:04 PM
Drives: 2002 Hyundai XG30
P0115
DESCRIPTION
The Engine Coolant Temperature (ECT) sensor is located in a coolant passage of the cylinder head. The ECT sensor is a variable resistor whose resistance changes as the temperature of the engine coolant flowing past the sensor changes. When the coolant temperature is low, the sensor resistance is high; when the coolant temperature is high, the sensor resistance is low. The Powertrain Control Module (PCM) checks ECT voltage fifty times per second and uses the information to help adjust the fuel injector pulse width and ignition timing. When the temperature sensed is very cold, the PCM enriches the fuel mixture.
This post has been edited by se4mus: May 23 2008, 04:27 PM
Attached File(s)
Greywolf
post May 23 2008, 09:36 PM
Well there you go, I was a fair way off !!!!
Since you aren't seeing any change in driveability, it must JUST be out of range. Otherwise you'd probably see a loss of power, and/or increased fuel consumption. Either that or you could be getting engine knock(or is it ping ? I just woke up) from the engine leaning out.
Montego should weigh in soon, the guy is an absolute demon with this stuff.
thafinestxg300
post May 27 2008, 11:22 AM
Drives: 2006 kia sorento 2001 xg300L
agreed with that i will check the hyundai book for other fixes or problems and check in later
Pilot84
post Jul 14 2008, 11:14 PM
Drives: XG 2001
thanks all for your help!
but does anyone have schematic diagrams for the engine? where do I find the ECT sensor to replace it?
montego
post Jul 15 2008, 02:54 PM
GLOBAL MODERATOR
Group Icon
Group: Super Mod
Drives: XG's (2001&2002)
go to www.hmaservice.com and register, you will find all the information that you need
Pilot84
post Jul 22 2008, 03:27 AM
Drives: XG 2001
Thank YOU!! :57:
Finny
post Jul 23 2008, 04:28 AM
Post #11
Drives: Hyundai Granduer 11/99 3litre
also do you know when your thermostat was last changed it can cause coolant issue as well could be jammed open there for car not running at the right temp
Pilot84
post Jul 24 2008, 08:23 PM
Post #12
Drives: XG 2001
no, don't know when it was last changed - dang.. will try and change the ECT sensor and see if it works first. I tried looking at the HMAservice website for the schematic diagrams for the engine so I know where to look for this part but can't find it. Anyone give me a hand? cheers
No New Posts Engine Damper
Is it worth it?
4 bloodninja 37 Yesterday, 08:07 PM
Last post by: bloodninja
No New Posts Engine Shut Off
What's going on?
20 penguin_hash 670 1st December 2008 - 09:58 AM
Last post by: wagsmachine
No New Posts Engine Wont Start When Hot
4 kev f 125 28th November 2008 - 12:56 AM
Last post by: Madogi
No New Posts Engine Ticking
1600 kms
13 Pinto_Siftbean 756 25th November 2008 - 05:19 PM
Last post by: david-paul-1
No New Posts Engine Oild Change Interval ?
23 montclare 487 23rd November 2008 - 07:49 PM
Last post by: Propflux01
3rd December 2008 - 12:27 AM
