 Hyundai-Forums.com > Hyundai Models > Tiburon Forum > RD Tiburon (1996-2001) > Installing Cylinder Head.....?
 Installing Cylinder Head.....?, turning the cams
stevogoggs
post May 21 2008, 12:26 AM
Drives: 1998 hyundai tiburon fx 2.0
Status: OFFLINE
i just rebuilt a head and torqued it to the block in the proper sequence to 26 ft lbs and layed the cams in and torqued the cam bearing caps down to 10-11 ft lbs and pored some oil in the head and was wondering if it should be hard to turn the timing cam gear by hand with a wrench.......it turns easy untill it pushed the spings down till the lobe is about to be strait down and the valve fully open but i cant get it to go fully over and open and close valves easly just wondering if it should be as easy as turning the crank?
User is offlineProfile CardPM
QuoteReply
montego
post May 21 2008, 12:08 PM
GLOBAL MODERATOR
Group Icon
Group Icon
Group: Super Mod
Drives: XG's (2001&2002)
Status: OFFLINE
on a twin cam. engine (l presume the cam. belt is not fitted yet) you can not just turn over one cam at a time because the valves will hit on the other cam. also make sure the the pistons are not at TDC or the valves will hit the piston
on a single cam. engine just make sure that the pistons are not at TDC
QuoteReply
stevogoggs
post May 21 2008, 05:39 PM
Status: OFFLINE
thanks man i fiqured out the problem i had the pistons up at top dead center i thought i moved thim im going good not just got to find out where all there pulleys and stuff go.
QuoteReply
> Link To Us
> Similar Threads
Installing Hid's
Forum : 4G (2006+) Sonata
hugamuto 459 25 Aug 22 2008, 03:24 PM
By: rallyman
Installing Xm In My 06 Sonata
UWISHU1 245 12 Aug 8 2008, 09:56 PM
By: joekewl
Ac Light Doesn't Work After Installing Radio
Forum : 2G (1996-2000) Elantra & Lantra
quagmire70 131 1 Aug 8 2008, 08:31 PM
By: promocom
New Aftermarket Head Unit In Sonata - Questions...
Forum : Car Audio, Video & Electronics
markymix 455 5 Aug 6 2008, 11:59 PM
By: joekewl
Installing Amp + Subs In Sonata
hyundai-idiot 320 8 Jul 31 2008, 05:23 PM
By: ReBeL_BLaK
28th August 2008 - 06:24 PM
