2001 Amica, 1.0 12v, 29,000 miles only, fully serviced with new plugs/leads/cambelt kit/tappets adjusted, mint in every way amazing condition, BUT....
... it has hesitation and lacks power, feels like the fuel is all wrong, over about 1/3 throttle. On light throttle it runs GREAT, can do 70mph on about 1/4 throttle, but only gets maybe 75mph flat out. Almost feels like putting more throttle on makes it slower.
I read the pending and stored fault codes, NONE. Nothing. I can't find any data anywhere to test the three things I feel may be causing the problem:
1) MAP sensor 2) Throttle Position Sensor (TPS) 3) 02 sensor, either before or after the cat (it has two).
I went for a drive and did some flat out driving and cruising, logged all the data, any comments appreciated. When I did the cambelt I couldn't see anything wrong with the reported issues with crank pulley which fits with it running very well on part throttle. It really feels like the fuel is wrong, it doesn't have that feel of a misfine. Also it starts great, any weather, runs great from cold - everything except run on over 1/3 throttle properly.
Another issue is when changing gear, it 'holds' the revs for a second, ie if doing say 3,000rpm and I put in the clutch with no throttle, it will continue to race at 3,000 for a second or so, makes it a pain to change up gear smoothly. As the throttle isn't sticking must be the idle stepper going wide during driving and closing a second or so after I take my foot off the throttle, pretty annoying and no idea what's causing it.
Two more things - when I look at the throttle position it says 0% at idle but full throttle only gives 75%. Should that be so? Or should I be reading 100% at full throttle? Also when it was left idling one for 10 mins, the idle speed gradually crept up and up in steps till it was doing about 2,500rpm. Didn't sort out till I shut off and restarted. Free throttle body and throttle cable, no issue there, so it was electronic.
Data below, any thoughts appreciated.
Greg.
Control Module $11 ISO 9141-2 Live Data DTC_CNT 0 FUELSYS1 CL FUELSYS2 N/A LOAD_PCT(%) 21.2 ETC(°C) 88 SHRTFT1(%) -4.7 LONGFT1(%) 0.8 MAP(kPa) 49 RPM(/min) 2959 VSS(km/h) 76 SPARKADV(°) 30 IAT(°C) 18 TP(%) 8.6 O2S B1S12--B2S---- O2B1S1(V) 0.655 SHRTFTB1S1(%) -3.9 O2B1S2(V) 0.615 OBD EOBD ------------------ DTC_CNT 0 FUELSYS1 CL FUELSYS2 N/A LOAD_PCT(%) 22.0 ETC(°C) 88 SHRTFT1(%) -2.3 LONGFT1(%) 0.8 MAP(kPa) 49 RPM(/min) 2917 VSS(km/h) 75 SPARKADV(°) 30 IAT(°C) 19 TP(%) 8.2 O2S B1S12--B2S---- O2B1S1(V) 0.195 SHRTFTB1S1(%) -6.3 O2B1S2(V) 0.610 OBD EOBD ------------------ DTC_CNT 0 FUELSYS1 OL-Drive FUELSYS2 N/A LOAD_PCT(%) 54.5 ETC(°C) 90 SHRTFT1(%) 0.0 LONGFT1(%) 0.8 MAP(kPa) 99 RPM(/min) 3204 VSS(km/h) 82 SPARKADV(°) 14 IAT(°C) 18 TP(%) 76.9 O2S B1S12--B2S---- O2B1S1(V) 0.800 SHRTFTB1S1(%) -3.1 O2B1S2(V) 0.680 OBD EOBD ------------------ DTC_CNT 0 FUELSYS1 CL FUELSYS2 N/A LOAD_PCT(%) 63.9 ETC(°C) 87 SHRTFT1(%) 1.6 LONGFT1(%) 0.8 MAP(kPa) 21 RPM(/min) 3212 VSS(km/h) 90 SPARKADV(°) 11 IAT(°C) 18 TP(%) 2.4 O2S B1S12--B2S---- O2B1S1(V) 0.770 SHRTFTB1S1(%) -5.5 O2B1S2(V) 0.220 OBD EOBD ------------------ DTC_CNT 0 FUELSYS1 OL-Drive FUELSYS2 N/A LOAD_PCT(%) 8.6 ETC(°C) 90 SHRTFT1(%) 0.0 LONGFT1(%) 0.8 MAP(kPa) 28 RPM(/min) 2596 VSS(km/h) 78 SPARKADV(°) 2 IAT(°C) 18 TP(%) 1.6 O2S B1S12--B2S---- O2B1S1(V) 0.720 SHRTFTB1S1(%) 2.3 O2B1S2(V) 0.695 OBD EOBD ------------------ DTC_CNT 0 FUELSYS1 OL-Drive FUELSYS2 N/A LOAD_PCT(%) 46.7 ETC(°C) 88 SHRTFT1(%) 0.0 LONGFT1(%) 0.8 MAP(kPa) 100 RPM(/min) 2718 VSS(km/h) 82 SPARKADV(°) 13 IAT(°C) 18 TP(%) 76.9 O2S B1S12--B2S---- O2B1S1(V) 0.810 SHRTFTB1S1(%) 0.0 O2B1S2(V) 0.800 OBD EOBD ------------------ DTC_CNT 0 FUELSYS1 OL-Drive FUELSYS2 N/A LOAD_PCT(%) 51.4 ETC(°C) 89 SHRTFT1(%) 0.0 LONGFT1(%) 0.8 MAP(kPa) 99 RPM(/min) 2947 VSS(km/h) 90 SPARKADV(°) 14 IAT(°C) 17 TP(%) 3.1 O2S B1S12--B2S---- O2B1S1(V) 0.710 SHRTFTB1S1(%) -6.3 O2B1S2(V) 0.755 OBD EOBD ------------------ DTC_CNT 0 FUELSYS1 CL FUELSYS2 N/A LOAD_PCT(%) 45.5 ETC(°C) 90 SHRTFT1(%) -2.3 LONGFT1(%) 0.8 MAP(kPa) 94 RPM(/min) 2799 VSS(km/h) 85 SPARKADV(°) 17 IAT(°C) 17 TP(%) 10.2 O2S B1S12--B2S---- O2B1S1(V) 0.725 SHRTFTB1S1(%) -6.3 O2B1S2(V) 0.580 OBD EOBD ------------------ DTC_CNT 0 FUELSYS1 OL-Drive FUELSYS2 N/A LOAD_PCT(%) 7.8 ETC(°C) 87 SHRTFT1(%) 0.0 LONGFT1(%) 0.8 MAP(kPa) 100 RPM(/min) 2556 VSS(km/h) 77 SPARKADV(°) 12 IAT(°C) 17 TP(%) 77.3 O2S B1S12--B2S---- O2B1S1(V) 0.795 SHRTFTB1S1(%) 0.0 O2B1S2(V) 0.795 OBD EOBD ------------------ DTC_CNT 0 FUELSYS1 OL-Drive FUELSYS2 N/A LOAD_PCT(%) 48.2 ETC(°C) 90 SHRTFT1(%) 0.0 LONGFT1(%) 0.8 MAP(kPa) 100 RPM(/min) 2767 VSS(km/h) 85 SPARKADV(°) 13 IAT(°C) 17 TP(%) 63.9 O2S B1S12--B2S---- O2B1S1(V) 0.720 SHRTFTB1S1(%) -8.6 O2B1S2(V) 0.785 OBD EOBD ------------------ DTC_CNT 0 FUELSYS1 OL-Drive FUELSYS2 N/A LOAD_PCT(%) 23.1 ETC(°C) 89 SHRTFT1(%) 1.6 LONGFT1(%) 0.8 MAP(kPa) 66 RPM(/min) 2441 VSS(km/h) 73 SPARKADV(°) 23 IAT(°C) 17 TP(%) 11.4 O2S B1S12--B2S---- O2B1S1(V) 0.700 SHRTFTB1S1(%) 0.0 O2B1S2(V) 0.455 OBD EOBD ------------------ DTC_CNT 0 FUELSYS1 CL FUELSYS2 N/A LOAD_PCT(%) 31.0 ETC(°C) 88 SHRTFT1(%) 3.1 LONGFT1(%) 0.8 MAP(kPa) 75 RPM(/min) 2483 VSS(km/h) 75 SPARKADV(°) 20 IAT(°C) 17 TP(%) 13.3 O2S B1S12--B2S---- O2B1S1(V) 0.660 SHRTFTB1S1(%) 1.6 O2B1S2(V) 0.610 OBD EOBD ------------------ DTC_CNT 0 FUELSYS1 CL FUELSYS2 N/A LOAD_PCT(%) 31.0 ETC(°C) 91 SHRTFT1(%) -3.1 LONGFT1(%) 0.8 MAP(kPa) 67 RPM(/min) 2513 VSS(km/h) 76 SPARKADV(°) 23 IAT(°C) 18 TP(%) 11.8 O2S B1S12--B2S---- O2B1S1(V) 0.680 SHRTFTB1S1(%) 0.8 O2B1S2(V) 0.615 OBD EOBD ------------------ DTC_CNT 0 FUELSYS1 CL FUELSYS2 N/A LOAD_PCT(%) 27.8 ETC(°C) 88 SHRTFT1(%) 1.6 LONGFT1(%) 0.8 MAP(kPa) 67 RPM(/min) 2543 VSS(km/h) 77 SPARKADV(°) 23 IAT(°C) 18 TP(%) 11.8 O2S B1S12--B2S---- O2B1S1(V) 0.675 SHRTFTB1S1(%) 2.3 O2B1S2(V) 0.600 OBD EOBD ------------------ DTC_CNT 0 FUELSYS1 CL FUELSYS2 N/A LOAD_PCT(%) 27.5 ETC(°C) 89 SHRTFT1(%) 0.8 LONGFT1(%) 0.8 MAP(kPa) 66 RPM(/min) 2558 VSS(km/h) 77 SPARKADV(°) 24 IAT(°C) 18 TP(%) 11.4 O2S B1S12--B2S---- O2B1S1(V) 0.570 SHRTFTB1S1(%) 3.1 O2B1S2(V) 0.595 OBD EOBD ------------------ DTC_CNT 0 FUELSYS1 CL FUELSYS2 N/A LOAD_PCT(%) 26.3 ETC(°C) 90 SHRTFT1(%) 0.0 LONGFT1(%) 0.8 MAP(kPa) 61 RPM(/min) 2584 VSS(km/h) 78 SPARKADV(°) 25 IAT(°C) 18 TP(%) 9.4 O2S B1S12--B2S---- O2B1S1(V) 0.605 SHRTFTB1S1(%) -0.8 O2B1S2(V) 0.575 OBD EOBD ------------------ DTC_CNT 0 FUELSYS1 CL FUELSYS2 N/A LOAD_PCT(%) 21.6 ETC(°C) 87 SHRTFT1(%) 0.0 LONGFT1(%) 0.8 MAP(kPa) 53 RPM(/min) 2582 VSS(km/h) 78 SPARKADV(°) 28 IAT(°C) 18 TP(%) 8.6 O2S B1S12--B2S---- O2B1S1(V) 0.100 SHRTFTB1S1(%) -1.6 O2B1S2(V) 0.570 OBD EOBD ------------------ DTC_CNT 0 FUELSYS1 CL FUELSYS2 N/A LOAD_PCT(%) 21.6 ETC(°C) 90 SHRTFT1(%) -0.8 LONGFT1(%) 0.8 MAP(kPa) 53 RPM(/min) 2575 VSS(km/h) 78 SPARKADV(°) 28 IAT(°C) 18 TP(%) 8.6 O2S B1S12--B2S---- O2B1S1(V) 0.335 SHRTFTB1S1(%) 3.1 O2B1S2(V) 0.575 OBD EOBD ------------------ DTC_CNT 0 FUELSYS1 CL FUELSYS2 N/A LOAD_PCT(%) 22.0 ETC(°C) 88 SHRTFT1(%) 1.6 LONGFT1(%) 0.8 MAP(kPa) 54 RPM(/min) 2557 VSS(km/h) 77 SPARKADV(°) 28 IAT(°C) 18 TP(%) 9.0 O2S B1S12--B2S---- O2B1S1(V) 0.150 SHRTFTB1S1(%) -1.6 O2B1S2(V) 0.550 OBD EOBD ------------------ DTC_CNT 0 FUELSYS1 OL-Drive FUELSYS2 N/A LOAD_PCT(%) 7.8 ETC(°C) 88 SHRTFT1(%) 0.0 LONGFT1(%) 0.8 MAP(kPa) 26 RPM(/min) 2343 VSS(km/h) 71 SPARKADV(°) 0 IAT(°C) 18 TP(%) 0.0 O2S B1S12--B2S---- O2B1S1(V) 0.000 SHRTFTB1S1(%) 0.0 O2B1S2(V) 0.000 OBD EOBD ------------------ DTC_CNT 0 FUELSYS1 OL-Drive FUELSYS2 N/A LOAD_PCT(%) 5.5 ETC(°C) 91 SHRTFT1(%) 0.0 LONGFT1(%) 0.8 MAP(kPa) 27 RPM(/min) 1814 VSS(km/h) 55 SPARKADV(°) -5 IAT(°C) 18 TP(%) 0.0 O2S B1S12--B2S---- O2B1S1(V) 0.000 SHRTFTB1S1(%) 0.0 O2B1S2(V) 0.000 OBD EOBD ------------------ DTC_CNT 0 FUELSYS1 OL-Drive FUELSYS2 N/A LOAD_PCT(%) 3.9 ETC(°C) 88 SHRTFT1(%) 0.8 LONGFT1(%) 0.8 MAP(kPa) 35 RPM(/min) 896 VSS(km/h) 35 SPARKADV(°) -4 IAT(°C) 18 TP(%) 0.0 O2S B1S12--B2S---- O2B1S1(V) 0.740 SHRTFTB1S1(%) -0.8 O2B1S2(V) 0.120 OBD EOBD ------------------ DTC_CNT 0 FUELSYS1 CL FUELSYS2 N/A LOAD_PCT(%) 8.6 ETC(°C) 88 SHRTFT1(%) 0.0 LONGFT1(%) 0.8 MAP(kPa) 41 RPM(/min) 1597 VSS(km/h) 30 SPARKADV(°) 27 IAT(°C) 19 TP(%) 3.1 O2S B1S12--B2S---- O2B1S1(V) 0.655 SHRTFTB1S1(%) -7.0 O2B1S2(V) 0.175 OBD EOBD ------------------ DTC_CNT 0 FUELSYS1 CL FUELSYS2 N/A LOAD_PCT(%) 4.3 ETC(°C) 90 SHRTFT1(%) 0.8 LONGFT1(%) 0.8 MAP(kPa) 34 RPM(/min) 1441 VSS(km/h) 25 SPARKADV(°) 26 IAT(°C) 19 TP(%) 2.7 O2S B1S12--B2S---- O2B1S1(V) 0.695 SHRTFTB1S1(%) -0.8 O2B1S2(V) 0.195 OBD EOBD ------------------ DTC_CNT 0 FUELSYS1 CL FUELSYS2 N/A LOAD_PCT(%) 14.9 ETC(°C) 90 SHRTFT1(%) 2.3 LONGFT1(%) 0.8 MAP(kPa) 101 RPM(/min) 1588 VSS(km/h) 28 SPARKADV(°) 5 IAT(°C) 20 TP(%) 77.3 O2S B1S12--B2S---- O2B1S1(V) 0.780 SHRTFTB1S1(%) 0.0 O2B1S2(V) 0.785 OBD EOBD ------------------ DTC_CNT 0 FUELSYS1 OL-Drive FUELSYS2 N/A LOAD_PCT(%) 44.3 ETC(°C) 89 SHRTFT1(%) 0.0 LONGFT1(%) 0.8 MAP(kPa) 100 RPM(/min) 2819 VSS(km/h) 52 SPARKADV(°) 14 IAT(°C) 18 TP(%) 77.3 O2S B1S12--B2S---- O2B1S1(V) 0.790 SHRTFTB1S1(%) 0.0 O2B1S2(V) 0.790 OBD EOBD ------------------ DTC_CNT 0 FUELSYS1 CL FUELSYS2 N/A LOAD_PCT(%) 69.8 ETC(°C) 89 SHRTFT1(%) 3.1 LONGFT1(%) 0.0 MAP(kPa) 99 RPM(/min) 4030 VSS(km/h) 72 SPARKADV(°) 13 IAT(°C) 18 TP(%) 77.3 O2S B1S12--B2S---- O2B1S1(V) 0.240 SHRTFTB1S1(%) 3.9 O2B1S2(V) 0.760 OBD EOBD ------------------ DTC_CNT 0 FUELSYS1 OL-Drive FUELSYS2 N/A LOAD_PCT(%) 89.0 ETC(°C) 87 SHRTFT1(%) 0.8 LONGFT1(%) 0.8 MAP(kPa) 36 RPM(/min) 3342 VSS(km/h) 86 SPARKADV(°) 13 IAT(°C) 16 TP(%) 77.3 O2S B1S12--B2S---- O2B1S1(V) 0.655 SHRTFTB1S1(%) -1.6 O2B1S2(V) 0.640 OBD EOBD ------------------ DTC_CNT 0 FUELSYS1 CL FUELSYS2 N/A LOAD_PCT(%) 24.3 ETC(°C) 90 SHRTFT1(%) 1.6 LONGFT1(%) 0.8 MAP(kPa) 22 RPM(/min) 3021 VSS(km/h) 90 SPARKADV(°) 15 IAT(°C) 16 TP(%) 19.2 O2S B1S12--B2S---- O2B1S1(V) 0.635 SHRTFTB1S1(%) 0.8 O2B1S2(V) 0.620 OBD EOBD ------------------ DTC_CNT 0 FUELSYS1 CL FUELSYS2 N/A LOAD_PCT(%) 18.0 ETC(°C) 90 SHRTFT1(%) -0.8 LONGFT1(%) 0.8 MAP(kPa) 45 RPM(/min) 2854 VSS(km/h) 87 SPARKADV(°) 32 IAT(°C) 16 TP(%) 8.6 O2S B1S12--B2S---- O2B1S1(V) 0.645 SHRTFTB1S1(%) 4.7 O2B1S2(V) 0.635 OBD EOBD ------------------ DTC_CNT 0 FUELSYS1 CL FUELSYS2 N/A LOAD_PCT(%) 31.4 ETC(°C) 89 SHRTFT1(%) 1.6 LONGFT1(%) 0.8 MAP(kPa) 72 RPM(/min) 2774 VSS(km/h) 85 SPARKADV(°) 20 IAT(°C) 18 TP(%) 14.5 O2S B1S12--B2S---- O2B1S1(V) 0.680 SHRTFTB1S1(%) 1.6 O2B1S2(V) 0.635 OBD EOBD ------------------ DTC_CNT 0 FUELSYS1 CL FUELSYS2 N/A LOAD_PCT(%) 42.0 ETC(°C) 91 SHRTFT1(%) -2.3 LONGFT1(%) 0.8 MAP(kPa) 79 RPM(/min) 2905 VSS(km/h) 88 SPARKADV(°) 20 IAT(°C) 18 TP(%) 16.1 O2S B1S12--B2S---- O2B1S1(V) 0.120 SHRTFTB1S1(%) -0.8 O2B1S2(V) 0.625 OBD EOBD ------------------ DTC_CNT 0 FUELSYS1 CL FUELSYS2 N/A LOAD_PCT(%) 48.2 ETC(°C) 88 SHRTFT1(%) -5.5 LONGFT1(%) 0.8 MAP(kPa) 95 RPM(/min) 3013 VSS(km/h) 92 SPARKADV(°) 14 IAT(°C) 17 TP(%) 27.8 O2S B1S12--B2S---- O2B1S1(V) 0.705 SHRTFTB1S1(%) -2.3 O2B1S2(V) 0.635 OBD EOBD ------------------ DTC_CNT 0 FUELSYS1 CL FUELSYS2 N/A LOAD_PCT(%) 50.6 ETC(°C) 89 SHRTFT1(%) 0.8 LONGFT1(%) 0.8 MAP(kPa) 94 RPM(/min) 3153 VSS(km/h) 96 SPARKADV(°) 14 IAT(°C) 16 TP(%) 27.5 O2S B1S12--B2S---- O2B1S1(V) 0.710 SHRTFTB1S1(%) 0.8 O2B1S2(V) 0.595 OBD EOBD ------------------ DTC_CNT 0 FUELSYS1 OL-Drive FUELSYS2 N/A LOAD_PCT(%) 8.6 ETC(°C) 89 SHRTFT1(%) 0.0 LONGFT1(%) 0.8 MAP(kPa) 71 RPM(/min) 3007 VSS(km/h) 92 SPARKADV(°) 14 IAT(°C) 16 TP(%) 28.6 O2S B1S12--B2S---- O2B1S1(V) 0.130 SHRTFTB1S1(%) -3.1 O2B1S2(V) 0.625 OBD EOBD ------------------ DTC_CNT 0 FUELSYS1 CL FUELSYS2 N/A LOAD_PCT(%) 53.3 ETC(°C) 87 SHRTFT1(%) -6.3 LONGFT1(%) 0.8 MAP(kPa) 99 RPM(/min) 3187 VSS(km/h) 96 SPARKADV(°) 14 IAT(°C) 16 TP(%) 77.3 O2S B1S12--B2S---- O2B1S1(V) 0.825 SHRTFTB1S1(%) 0.0 O2B1S2(V) 0.805 OBD EOBD ------------------ DTC_CNT 0 FUELSYS1 OL-Drive FUELSYS2 N/A LOAD_PCT(%) 8.6 ETC(°C) 90 SHRTFT1(%) 0.0 LONGFT1(%) 0.8 MAP(kPa) 27 RPM(/min) 2941 VSS(km/h) 90 SPARKADV(°) 25 IAT(°C) 16 TP(%) 29.8 O2S B1S12--B2S---- O2B1S1(V) 0.105 SHRTFTB1S1(%) 0.8 O2B1S2(V) 0.540 OBD EOBD ------------------ DTC_CNT 0 FUELSYS1 OL-Drive FUELSYS2 N/A LOAD_PCT(%) 54.5 ETC(°C) 87 SHRTFT1(%) 0.0 LONGFT1(%) 0.8 MAP(kPa) 99 RPM(/min) 3160 VSS(km/h) 96 SPARKADV(°) 14 IAT(°C) 16 TP(%) 76.9 O2S B1S12--B2S---- O2B1S1(V) 0.820 SHRTFTB1S1(%) 0.0 O2B1S2(V) 0.805 OBD EOBD ------------------ DTC_CNT 0 FUELSYS1 CL FUELSYS2 N/A LOAD_PCT(%) 18.0 ETC(°C) 90 SHRTFT1(%) -0.8 LONGFT1(%) 0.8 MAP(kPa) 21 RPM(/min) 3173 VSS(km/h) 96 SPARKADV(°) 2 IAT(°C) 15 TP(%) 0.0 O2S B1S12--B2S---- O2B1S1(V) 0.000 SHRTFTB1S1(%) 0.0 O2B1S2(V) 0.000 OBD EOBD ------------------ DTC_CNT 0 FUELSYS1 OL-Drive FUELSYS2 N/A LOAD_PCT(%) 36.9 ETC(°C) 87 SHRTFT1(%) 0.8 LONGFT1(%) 0.8 MAP(kPa) 75 RPM(/min) 2923 VSS(km/h) 88 SPARKADV(°) 20 IAT(°C) 16 TP(%) 10.6 O2S B1S12--B2S---- O2B1S1(V) 0.675 SHRTFTB1S1(%) 3.9 O2B1S2(V) 0.580 OBD EOBD ------------------ DTC_CNT 0 FUELSYS1 CL FUELSYS2 N/A LOAD_PCT(%) 38.4 ETC(°C) 89 SHRTFT1(%) 1.6 LONGFT1(%) 0.8 MAP(kPa) 78 RPM(/min) 2955 VSS(km/h) 90 SPARKADV(°) 24 IAT(°C) 17 TP(%) 9.0 O2S B1S12--B2S---- O2B1S1(V) 0.715 SHRTFTB1S1(%) -2.3 O2B1S2(V) 0.645 OBD EOBD ------------------ DTC_CNT 0 FUELSYS1 OL-Drive FUELSYS2 N/A LOAD_PCT(%) 8.2 ETC(°C) 89 SHRTFT1(%) 0.0 LONGFT1(%) 0.8 MAP(kPa) 27 RPM(/min) 2702 VSS(km/h) 82 SPARKADV(°) 18 IAT(°C) 17 TP(%) 14.1 O2S B1S12--B2S---- O2B1S1(V) 0.175 SHRTFTB1S1(%) 0.0 O2B1S2(V) 0.540 OBD EOBD ------------------ DTC_CNT 0 FUELSYS1 CL FUELSYS2 N/A LOAD_PCT(%) 16.5 ETC(°C) 87 SHRTFT1(%) -2.3 LONGFT1(%) 0.8 MAP(kPa) 61 RPM(/min) 2705 VSS(km/h) 82 SPARKADV(°) 14 IAT(°C) 18 TP(%) 21.2 O2S B1S12--B2S---- O2B1S1(V) 0.665 SHRTFTB1S1(%) 0.8 O2B1S2(V) 0.685 OBD EOBD ------------------ DTC_CNT 0 FUELSYS1 OL-Drive FUELSYS2 N/A LOAD_PCT(%) 50.2 ETC(°C) 90 SHRTFT1(%) 0.0 LONGFT1(%) 0.8 MAP(kPa) 100 RPM(/min) 2936 VSS(km/h) 90 SPARKADV(°) 14 IAT(°C) 17 TP(%) 76.9 O2S B1S12--B2S---- O2B1S1(V) 0.810 SHRTFTB1S1(%) 0.0 O2B1S2(V) 0.805 OBD EOBD ------------------ DTC_CNT 0 FUELSYS1 OL-Drive FUELSYS2 N/A LOAD_PCT(%) 55.7 ETC(°C) 87 SHRTFT1(%) 0.0 LONGFT1(%) 0.8 MAP(kPa) 100 RPM(/min) 3182 VSS(km/h) 97 SPARKADV(°) 14 IAT(°C) 16 TP(%) 76.9 O2S B1S12--B2S---- O2B1S1(V) 0.815 SHRTFTB1S1(%) 0.0 O2B1S2(V) 0.800 OBD EOBD ------------------ DTC_CNT 0 FUELSYS1 CL FUELSYS2 N/A LOAD_PCT(%) 5.5 ETC(°C) 90 SHRTFT1(%) 0.0 LONGFT1(%) 0.8 MAP(kPa) 26 RPM(/min) 3082 VSS(km/h) 93 SPARKADV(°) 2 IAT(°C) 15 TP(%) 0.0 O2S B1S12--B2S---- O2B1S1(V) 0.000 SHRTFTB1S1(%) 0.0 O2B1S2(V) 0.000 OBD EOBD ------------------ DTC_CNT 0 FUELSYS1 OL-Drive FUELSYS2 N/A LOAD_PCT(%) 22.7 ETC(°C) 87 SHRTFT1(%) -2.3 LONGFT1(%) 0.8 MAP(kPa) 53 RPM(/min) 2774 VSS(km/h) 85 SPARKADV(°) 28 IAT(°C) 16 TP(%) 9.0 O2S B1S12--B2S---- O2B1S1(V) 0.695 SHRTFTB1S1(%) 0.0 O2B1S2(V) 0.565 OBD EOBD ------------------ DTC_CNT 0 FUELSYS1 CL FUELSYS2 N/A LOAD_PCT(%) 8.6 ETC(°C) 88 SHRTFT1(%) -7.0 LONGFT1(%) 0.8 MAP(kPa) 27 RPM(/min) 2605 VSS(km/h) 78 SPARKADV(°) 2 IAT(°C) 17 TP(%) 0.0 O2S B1S12--B2S---- O2B1S1(V) 0.000 SHRTFTB1S1(%) 0.0 O2B1S2(V) 0.000 OBD EOBD ------------------ DTC_CNT 0 FUELSYS1 CL FUELSYS2 N/A LOAD_PCT(%) 40.8 ETC(°C) 90 SHRTFT1(%) -0.8 LONGFT1(%) 0.8 MAP(kPa) 94 RPM(/min) 2516 VSS(km/h) 76 SPARKADV(°) 10 IAT(°C) 18 TP(%) 27.1 O2S B1S12--B2S---- O2B1S1(V) 0.635 SHRTFTB1S1(%) 3.1 O2B1S2(V) 0.630 OBD EOBD ------------------ DTC_CNT 0 FUELSYS1 CL FUELSYS2 N/A LOAD_PCT(%) 40.8 ETC(°C) 88 SHRTFT1(%) 1.6 LONGFT1(%) 0.8 MAP(kPa) 81 RPM(/min) 2612 VSS(km/h) 81 SPARKADV(°) 24 IAT(°C) 17 TP(%) 11.4 O2S B1S12--B2S---- O2B1S1(V) 0.640 SHRTFTB1S1(%) 3.9 O2B1S2(V) 0.620 OBD EOBD ------------------ DTC_CNT 0 FUELSYS1 CL FUELSYS2 N/A LOAD_PCT(%) 25.9 ETC(°C) 90 SHRTFT1(%) 0.0 LONGFT1(%) 0.8 MAP(kPa) 65 RPM(/min) 2622 VSS(km/h) 80 SPARKADV(°) 24 IAT(°C) 17 TP(%) 11.4 O2S B1S12--B2S---- O2B1S1(V) 0.260 SHRTFTB1S1(%) 0.8 O2B1S2(V) 0.615 OBD EOBD ------------------ DTC_CNT 0 FUELSYS1 CL FUELSYS2 N/A LOAD_PCT(%) 27.5 ETC(°C) 88 SHRTFT1(%) 1.6 LONGFT1(%) 0.8 MAP(kPa) 65 RPM(/min) 2640 VSS(km/h) 80 SPARKADV(°) 25 IAT(°C) 17 TP(%) 10.6 O2S B1S12--B2S---- O2B1S1(V) 0.340 SHRTFTB1S1(%) -0.8 O2B1S2(V) 0.600 OBD EOBD ------------------ DTC_CNT 0 FUELSYS1 CL FUELSYS2 N/A LOAD_PCT(%) 24.7 ETC(°C) 88 SHRTFT1(%) 3.1 LONGFT1(%) 0.8 MAP(kPa) 63 RPM(/min) 2600 VSS(km/h) 80 SPARKADV(°) 25 IAT(°C) 17 TP(%) 11.4 O2S B1S12--B2S---- O2B1S1(V) 0.215 SHRTFTB1S1(%) -1.6 O2B1S2(V) 0.590 OBD EOBD ------------------ DTC_CNT 0 FUELSYS1 CL FUELSYS2 N/A LOAD_PCT(%) 27.1 ETC(°C) 91 SHRTFT1(%) -1.6 LONGFT1(%) 0.8 MAP(kPa) 66 RPM(/min) 2596 VSS(km/h) 78 SPARKADV(°) 24 IAT(°C) 18 TP(%) 11.8 O2S B1S12--B2S---- O2B1S1(V) 0.440 SHRTFTB1S1(%) 0.0 O2B1S2(V) 0.580 OBD EOBD ------------------ DTC_CNT 0 FUELSYS1 CL FUELSYS2 N/A LOAD_PCT(%) 44.3 ETC(°C) 88 SHRTFT1(%) 0.0 LONGFT1(%) 0.8 MAP(kPa) 100 RPM(/min) 2625 VSS(km/h) 80 SPARKADV(°) 10 IAT(°C) 18 TP(%) 47.8 O2S B1S12--B2S---- O2B1S1(V) 0.185 SHRTFTB1S1(%) -7.0 O2B1S2(V) 0.640 OBD EOBD ------------------ DTC_CNT 0 FUELSYS1 CL FUELSYS2 N/A LOAD_PCT(%) 46.3 ETC(°C) 90 SHRTFT1(%) -3.1 LONGFT1(%) 0.8 MAP(kPa) 24 RPM(/min) 2638 VSS(km/h) 80 SPARKADV(°) 2 IAT(°C) 16 TP(%) 0.0 O2S B1S12--B2S---- O2B1S1(V) 0.000 SHRTFTB1S1(%) 0.0 O2B1S2(V) 0.000 OBD EOBD ------------------ DTC_CNT 0 FUELSYS1 OL-Drive FUELSYS2 N/A LOAD_PCT(%) 5.9 ETC(°C) 89 SHRTFT1(%) 0.0 LONGFT1(%) 0.8 MAP(kPa) 67 RPM(/min) 2016 VSS(km/h) 61 SPARKADV(°) 15 IAT(°C) 17 TP(%) 12.5 O2S B1S12--B2S---- O2B1S1(V) 0.170 SHRTFTB1S1(%) 0.8 O2B1S2(V) 0.525 OBD EOBD ------------------ DTC_CNT 0 FUELSYS1 CL FUELSYS2 N/A LOAD_PCT(%) 25.5 ETC(°C) 88 SHRTFT1(%) 1.6 LONGFT1(%) 0.8 MAP(kPa) 76 RPM(/min) 2059 VSS(km/h) 62 SPARKADV(°) 15 IAT(°C) 17 TP(%) 12.2 O2S B1S12--B2S---- O2B1S1(V) 0.220 SHRTFTB1S1(%) 3.9 O2B1S2(V) 0.630 OBD EOBD ------------------ DTC_CNT 0 FUELSYS1 CL FUELSYS2 N/A LOAD_PCT(%) 25.9 ETC(°C) 91 SHRTFT1(%) 0.0 LONGFT1(%) 0.8 MAP(kPa) 76 RPM(/min) 2079 VSS(km/h) 62 SPARKADV(°) 15 IAT(°C) 18 TP(%) 12.2 O2S B1S12--B2S---- O2B1S1(V) 0.640 SHRTFTB1S1(%) 0.8 O2B1S2(V) 0.630 OBD EOBD ------------------ DTC_CNT 0 FUELSYS1 CL FUELSYS2 N/A LOAD_PCT(%) 26.3 ETC(°C) 89 SHRTFT1(%) 0.0 LONGFT1(%) 0.8 MAP(kPa) 77 RPM(/min) 2084 VSS(km/h) 63 SPARKADV(°) 15 IAT(°C) 18 TP(%) 12.5 O2S B1S12--B2S---- O2B1S1(V) 0.650 SHRTFTB1S1(%) 0.0 O2B1S2(V) 0.615 OBD EOBD ------------------
