 Hyundai-Forums.com > Hyundai Models > Amica & Atoz Forum > 1.0 Hesitation, No Fault Codes, Diagnosis? Here's
greg123
post May 20 2008, 05:36 PM
Drives: Amica GSi, 1.0 efi 12v, 2001
Status: OFFLINE
2001 Amica, 1.0 12v, 29,000 miles only, fully serviced with new plugs/leads/cambelt kit/tappets adjusted, mint in every way amazing condition, BUT....
... it has hesitation and lacks power, feels like the fuel is all wrong, over about 1/3 throttle. On light throttle it runs GREAT, can do 70mph on about 1/4 throttle, but only gets maybe 75mph flat out. Almost feels like putting more throttle on makes it slower.
I read the pending and stored fault codes, NONE. Nothing. I can't find any data anywhere to test the three things I feel may be causing the problem:
1) MAP sensor
2) Throttle Position Sensor (TPS)
3) 02 sensor, either before or after the cat (it has two).
I went for a drive and did some flat out driving and cruising, logged all the data, any comments appreciated. When I did the cambelt I couldn't see anything wrong with the reported issues with crank pulley which fits with it running very well on part throttle. It really feels like the fuel is wrong, it doesn't have that feel of a misfine. Also it starts great, any weather, runs great from cold - everything except run on over 1/3 throttle properly.
Another issue is when changing gear, it 'holds' the revs for a second, ie if doing say 3,000rpm and I put in the clutch with no throttle, it will continue to race at 3,000 for a second or so, makes it a pain to change up gear smoothly. As the throttle isn't sticking must be the idle stepper going wide during driving and closing a second or so after I take my foot off the throttle, pretty annoying and no idea what's causing it.
Two more things - when I look at the throttle position it says 0% at idle but full throttle only gives 75%. Should that be so? Or should I be reading 100% at full throttle? Also when it was left idling one for 10 mins, the idle speed gradually crept up and up in steps till it was doing about 2,500rpm. Didn't sort out till I shut off and restarted. Free throttle body and throttle cable, no issue there, so it was electronic.
Data below, any thoughts appreciated.
Greg.
Control Module
$11 ISO 9141-2
Live Data
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 21.2
ETC(°C) 88
SHRTFT1(%) -4.7
LONGFT1(%) 0.8
MAP(kPa) 49
RPM(/min) 2959
VSS(km/h) 76
SPARKADV(°) 30
IAT(°C) 18
TP(%) 8.6
O2S B1S12--B2S----
O2B1S1(V) 0.655
SHRTFTB1S1(%) -3.9
O2B1S2(V) 0.615
OBD EOBD
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 22.0
ETC(°C) 88
SHRTFT1(%) -2.3
LONGFT1(%) 0.8
MAP(kPa) 49
RPM(/min) 2917
VSS(km/h) 75
SPARKADV(°) 30
IAT(°C) 19
TP(%) 8.2
O2S B1S12--B2S----
O2B1S1(V) 0.195
SHRTFTB1S1(%) -6.3
O2B1S2(V) 0.610
OBD EOBD
DTC_CNT 0
FUELSYS1 OL-Drive
FUELSYS2 N/A
LOAD_PCT(%) 54.5
ETC(°C) 90
SHRTFT1(%) 0.0
LONGFT1(%) 0.8
MAP(kPa) 99
RPM(/min) 3204
VSS(km/h) 82
SPARKADV(°) 14
IAT(°C) 18
TP(%) 76.9
O2S B1S12--B2S----
O2B1S1(V) 0.800
SHRTFTB1S1(%) -3.1
O2B1S2(V) 0.680
OBD EOBD
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 63.9
ETC(°C) 87
SHRTFT1(%) 1.6
LONGFT1(%) 0.8
MAP(kPa) 21
RPM(/min) 3212
VSS(km/h) 90
SPARKADV(°) 11
IAT(°C) 18
TP(%) 2.4
O2S B1S12--B2S----
O2B1S1(V) 0.770
SHRTFTB1S1(%) -5.5
O2B1S2(V) 0.220
OBD EOBD
DTC_CNT 0
FUELSYS1 OL-Drive
FUELSYS2 N/A
LOAD_PCT(%) 8.6
ETC(°C) 90
SHRTFT1(%) 0.0
LONGFT1(%) 0.8
MAP(kPa) 28
RPM(/min) 2596
VSS(km/h) 78
SPARKADV(°) 2
IAT(°C) 18
TP(%) 1.6
O2S B1S12--B2S----
O2B1S1(V) 0.720
SHRTFTB1S1(%) 2.3
O2B1S2(V) 0.695
OBD EOBD
DTC_CNT 0
FUELSYS1 OL-Drive
FUELSYS2 N/A
LOAD_PCT(%) 46.7
ETC(°C) 88
SHRTFT1(%) 0.0
LONGFT1(%) 0.8
MAP(kPa) 100
RPM(/min) 2718
VSS(km/h) 82
SPARKADV(°) 13
IAT(°C) 18
TP(%) 76.9
O2S B1S12--B2S----
O2B1S1(V) 0.810
SHRTFTB1S1(%) 0.0
O2B1S2(V) 0.800
OBD EOBD
DTC_CNT 0
FUELSYS1 OL-Drive
FUELSYS2 N/A
LOAD_PCT(%) 51.4
ETC(°C) 89
SHRTFT1(%) 0.0
LONGFT1(%) 0.8
MAP(kPa) 99
RPM(/min) 2947
VSS(km/h) 90
SPARKADV(°) 14
IAT(°C) 17
TP(%) 3.1
O2S B1S12--B2S----
O2B1S1(V) 0.710
SHRTFTB1S1(%) -6.3
O2B1S2(V) 0.755
OBD EOBD
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 45.5
ETC(°C) 90
SHRTFT1(%) -2.3
LONGFT1(%) 0.8
MAP(kPa) 94
RPM(/min) 2799
VSS(km/h) 85
SPARKADV(°) 17
IAT(°C) 17
TP(%) 10.2
O2S B1S12--B2S----
O2B1S1(V) 0.725
SHRTFTB1S1(%) -6.3
O2B1S2(V) 0.580
OBD EOBD
DTC_CNT 0
FUELSYS1 OL-Drive
FUELSYS2 N/A
LOAD_PCT(%) 7.8
ETC(°C) 87
SHRTFT1(%) 0.0
LONGFT1(%) 0.8
MAP(kPa) 100
RPM(/min) 2556
VSS(km/h) 77
SPARKADV(°) 12
IAT(°C) 17
TP(%) 77.3
O2S B1S12--B2S----
O2B1S1(V) 0.795
SHRTFTB1S1(%) 0.0
O2B1S2(V) 0.795
OBD EOBD
DTC_CNT 0
FUELSYS1 OL-Drive
FUELSYS2 N/A
LOAD_PCT(%) 48.2
ETC(°C) 90
SHRTFT1(%) 0.0
LONGFT1(%) 0.8
MAP(kPa) 100
RPM(/min) 2767
VSS(km/h) 85
SPARKADV(°) 13
IAT(°C) 17
TP(%) 63.9
O2S B1S12--B2S----
O2B1S1(V) 0.720
SHRTFTB1S1(%) -8.6
O2B1S2(V) 0.785
OBD EOBD
DTC_CNT 0
FUELSYS1 OL-Drive
FUELSYS2 N/A
LOAD_PCT(%) 23.1
ETC(°C) 89
SHRTFT1(%) 1.6
LONGFT1(%) 0.8
MAP(kPa) 66
RPM(/min) 2441
VSS(km/h) 73
SPARKADV(°) 23
IAT(°C) 17
TP(%) 11.4
O2S B1S12--B2S----
O2B1S1(V) 0.700
SHRTFTB1S1(%) 0.0
O2B1S2(V) 0.455
OBD EOBD
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 31.0
ETC(°C) 88
SHRTFT1(%) 3.1
LONGFT1(%) 0.8
MAP(kPa) 75
RPM(/min) 2483
VSS(km/h) 75
SPARKADV(°) 20
IAT(°C) 17
TP(%) 13.3
O2S B1S12--B2S----
O2B1S1(V) 0.660
SHRTFTB1S1(%) 1.6
O2B1S2(V) 0.610
OBD EOBD
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 31.0
ETC(°C) 91
SHRTFT1(%) -3.1
LONGFT1(%) 0.8
MAP(kPa) 67
RPM(/min) 2513
VSS(km/h) 76
SPARKADV(°) 23
IAT(°C) 18
TP(%) 11.8
O2S B1S12--B2S----
O2B1S1(V) 0.680
SHRTFTB1S1(%) 0.8
O2B1S2(V) 0.615
OBD EOBD
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 27.8
ETC(°C) 88
SHRTFT1(%) 1.6
LONGFT1(%) 0.8
MAP(kPa) 67
RPM(/min) 2543
VSS(km/h) 77
SPARKADV(°) 23
IAT(°C) 18
TP(%) 11.8
O2S B1S12--B2S----
O2B1S1(V) 0.675
SHRTFTB1S1(%) 2.3
O2B1S2(V) 0.600
OBD EOBD
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 27.5
ETC(°C) 89
SHRTFT1(%) 0.8
LONGFT1(%) 0.8
MAP(kPa) 66
RPM(/min) 2558
VSS(km/h) 77
SPARKADV(°) 24
IAT(°C) 18
TP(%) 11.4
O2S B1S12--B2S----
O2B1S1(V) 0.570
SHRTFTB1S1(%) 3.1
O2B1S2(V) 0.595
OBD EOBD
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 26.3
ETC(°C) 90
SHRTFT1(%) 0.0
LONGFT1(%) 0.8
MAP(kPa) 61
RPM(/min) 2584
VSS(km/h) 78
SPARKADV(°) 25
IAT(°C) 18
TP(%) 9.4
O2S B1S12--B2S----
O2B1S1(V) 0.605
SHRTFTB1S1(%) -0.8
O2B1S2(V) 0.575
OBD EOBD
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 21.6
ETC(°C) 87
SHRTFT1(%) 0.0
LONGFT1(%) 0.8
MAP(kPa) 53
RPM(/min) 2582
VSS(km/h) 78
SPARKADV(°) 28
IAT(°C) 18
TP(%) 8.6
O2S B1S12--B2S----
O2B1S1(V) 0.100
SHRTFTB1S1(%) -1.6
O2B1S2(V) 0.570
OBD EOBD
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 21.6
ETC(°C) 90
SHRTFT1(%) -0.8
LONGFT1(%) 0.8
MAP(kPa) 53
RPM(/min) 2575
VSS(km/h) 78
SPARKADV(°) 28
IAT(°C) 18
TP(%) 8.6
O2S B1S12--B2S----
O2B1S1(V) 0.335
SHRTFTB1S1(%) 3.1
O2B1S2(V) 0.575
OBD EOBD
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 22.0
ETC(°C) 88
SHRTFT1(%) 1.6
LONGFT1(%) 0.8
MAP(kPa) 54
RPM(/min) 2557
VSS(km/h) 77
SPARKADV(°) 28
IAT(°C) 18
TP(%) 9.0
O2S B1S12--B2S----
O2B1S1(V) 0.150
SHRTFTB1S1(%) -1.6
O2B1S2(V) 0.550
OBD EOBD
DTC_CNT 0
FUELSYS1 OL-Drive
FUELSYS2 N/A
LOAD_PCT(%) 7.8
ETC(°C) 88
SHRTFT1(%) 0.0
LONGFT1(%) 0.8
MAP(kPa) 26
RPM(/min) 2343
VSS(km/h) 71
SPARKADV(°) 0
IAT(°C) 18
TP(%) 0.0
O2S B1S12--B2S----
O2B1S1(V) 0.000
SHRTFTB1S1(%) 0.0
O2B1S2(V) 0.000
OBD EOBD
DTC_CNT 0
FUELSYS1 OL-Drive
FUELSYS2 N/A
LOAD_PCT(%) 5.5
ETC(°C) 91
SHRTFT1(%) 0.0
LONGFT1(%) 0.8
MAP(kPa) 27
RPM(/min) 1814
VSS(km/h) 55
SPARKADV(°) -5
IAT(°C) 18
TP(%) 0.0
O2S B1S12--B2S----
O2B1S1(V) 0.000
SHRTFTB1S1(%) 0.0
O2B1S2(V) 0.000
OBD EOBD
DTC_CNT 0
FUELSYS1 OL-Drive
FUELSYS2 N/A
LOAD_PCT(%) 3.9
ETC(°C) 88
SHRTFT1(%) 0.8
LONGFT1(%) 0.8
MAP(kPa) 35
RPM(/min) 896
VSS(km/h) 35
SPARKADV(°) -4
IAT(°C) 18
TP(%) 0.0
O2S B1S12--B2S----
O2B1S1(V) 0.740
SHRTFTB1S1(%) -0.8
O2B1S2(V) 0.120
OBD EOBD
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 8.6
ETC(°C) 88
SHRTFT1(%) 0.0
LONGFT1(%) 0.8
MAP(kPa) 41
RPM(/min) 1597
VSS(km/h) 30
SPARKADV(°) 27
IAT(°C) 19
TP(%) 3.1
O2S B1S12--B2S----
O2B1S1(V) 0.655
SHRTFTB1S1(%) -7.0
O2B1S2(V) 0.175
OBD EOBD
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 4.3
ETC(°C) 90
SHRTFT1(%) 0.8
LONGFT1(%) 0.8
MAP(kPa) 34
RPM(/min) 1441
VSS(km/h) 25
SPARKADV(°) 26
IAT(°C) 19
TP(%) 2.7
O2S B1S12--B2S----
O2B1S1(V) 0.695
SHRTFTB1S1(%) -0.8
O2B1S2(V) 0.195
OBD EOBD
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 14.9
ETC(°C) 90
SHRTFT1(%) 2.3
LONGFT1(%) 0.8
MAP(kPa) 101
RPM(/min) 1588
VSS(km/h) 28
SPARKADV(°) 5
IAT(°C) 20
TP(%) 77.3
O2S B1S12--B2S----
O2B1S1(V) 0.780
SHRTFTB1S1(%) 0.0
O2B1S2(V) 0.785
OBD EOBD
DTC_CNT 0
FUELSYS1 OL-Drive
FUELSYS2 N/A
LOAD_PCT(%) 44.3
ETC(°C) 89
SHRTFT1(%) 0.0
LONGFT1(%) 0.8
MAP(kPa) 100
RPM(/min) 2819
VSS(km/h) 52
SPARKADV(°) 14
IAT(°C) 18
TP(%) 77.3
O2S B1S12--B2S----
O2B1S1(V) 0.790
SHRTFTB1S1(%) 0.0
O2B1S2(V) 0.790
OBD EOBD
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 69.8
ETC(°C) 89
SHRTFT1(%) 3.1
LONGFT1(%) 0.0
MAP(kPa) 99
RPM(/min) 4030
VSS(km/h) 72
SPARKADV(°) 13
IAT(°C) 18
TP(%) 77.3
O2S B1S12--B2S----
O2B1S1(V) 0.240
SHRTFTB1S1(%) 3.9
O2B1S2(V) 0.760
OBD EOBD
DTC_CNT 0
FUELSYS1 OL-Drive
FUELSYS2 N/A
LOAD_PCT(%) 89.0
ETC(°C) 87
SHRTFT1(%) 0.8
LONGFT1(%) 0.8
MAP(kPa) 36
RPM(/min) 3342
VSS(km/h) 86
SPARKADV(°) 13
IAT(°C) 16
TP(%) 77.3
O2S B1S12--B2S----
O2B1S1(V) 0.655
SHRTFTB1S1(%) -1.6
O2B1S2(V) 0.640
OBD EOBD
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 24.3
ETC(°C) 90
SHRTFT1(%) 1.6
LONGFT1(%) 0.8
MAP(kPa) 22
RPM(/min) 3021
VSS(km/h) 90
SPARKADV(°) 15
IAT(°C) 16
TP(%) 19.2
O2S B1S12--B2S----
O2B1S1(V) 0.635
SHRTFTB1S1(%) 0.8
O2B1S2(V) 0.620
OBD EOBD
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 18.0
ETC(°C) 90
SHRTFT1(%) -0.8
LONGFT1(%) 0.8
MAP(kPa) 45
RPM(/min) 2854
VSS(km/h) 87
SPARKADV(°) 32
IAT(°C) 16
TP(%) 8.6
O2S B1S12--B2S----
O2B1S1(V) 0.645
SHRTFTB1S1(%) 4.7
O2B1S2(V) 0.635
OBD EOBD
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 31.4
ETC(°C) 89
SHRTFT1(%) 1.6
LONGFT1(%) 0.8
MAP(kPa) 72
RPM(/min) 2774
VSS(km/h) 85
SPARKADV(°) 20
IAT(°C) 18
TP(%) 14.5
O2S B1S12--B2S----
O2B1S1(V) 0.680
SHRTFTB1S1(%) 1.6
O2B1S2(V) 0.635
OBD EOBD
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 42.0
ETC(°C) 91
SHRTFT1(%) -2.3
LONGFT1(%) 0.8
MAP(kPa) 79
RPM(/min) 2905
VSS(km/h) 88
SPARKADV(°) 20
IAT(°C) 18
TP(%) 16.1
O2S B1S12--B2S----
O2B1S1(V) 0.120
SHRTFTB1S1(%) -0.8
O2B1S2(V) 0.625
OBD EOBD
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 48.2
ETC(°C) 88
SHRTFT1(%) -5.5
LONGFT1(%) 0.8
MAP(kPa) 95
RPM(/min) 3013
VSS(km/h) 92
SPARKADV(°) 14
IAT(°C) 17
TP(%) 27.8
O2S B1S12--B2S----
O2B1S1(V) 0.705
SHRTFTB1S1(%) -2.3
O2B1S2(V) 0.635
OBD EOBD
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 50.6
ETC(°C) 89
SHRTFT1(%) 0.8
LONGFT1(%) 0.8
MAP(kPa) 94
RPM(/min) 3153
VSS(km/h) 96
SPARKADV(°) 14
IAT(°C) 16
TP(%) 27.5
O2S B1S12--B2S----
O2B1S1(V) 0.710
SHRTFTB1S1(%) 0.8
O2B1S2(V) 0.595
OBD EOBD
DTC_CNT 0
FUELSYS1 OL-Drive
FUELSYS2 N/A
LOAD_PCT(%) 8.6
ETC(°C) 89
SHRTFT1(%) 0.0
LONGFT1(%) 0.8
MAP(kPa) 71
RPM(/min) 3007
VSS(km/h) 92
SPARKADV(°) 14
IAT(°C) 16
TP(%) 28.6
O2S B1S12--B2S----
O2B1S1(V) 0.130
SHRTFTB1S1(%) -3.1
O2B1S2(V) 0.625
OBD EOBD
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 53.3
ETC(°C) 87
SHRTFT1(%) -6.3
LONGFT1(%) 0.8
MAP(kPa) 99
RPM(/min) 3187
VSS(km/h) 96
SPARKADV(°) 14
IAT(°C) 16
TP(%) 77.3
O2S B1S12--B2S----
O2B1S1(V) 0.825
SHRTFTB1S1(%) 0.0
O2B1S2(V) 0.805
OBD EOBD
DTC_CNT 0
FUELSYS1 OL-Drive
FUELSYS2 N/A
LOAD_PCT(%) 8.6
ETC(°C) 90
SHRTFT1(%) 0.0
LONGFT1(%) 0.8
MAP(kPa) 27
RPM(/min) 2941
VSS(km/h) 90
SPARKADV(°) 25
IAT(°C) 16
TP(%) 29.8
O2S B1S12--B2S----
O2B1S1(V) 0.105
SHRTFTB1S1(%) 0.8
O2B1S2(V) 0.540
OBD EOBD
DTC_CNT 0
FUELSYS1 OL-Drive
FUELSYS2 N/A
LOAD_PCT(%) 54.5
ETC(°C) 87
SHRTFT1(%) 0.0
LONGFT1(%) 0.8
MAP(kPa) 99
RPM(/min) 3160
VSS(km/h) 96
SPARKADV(°) 14
IAT(°C) 16
TP(%) 76.9
O2S B1S12--B2S----
O2B1S1(V) 0.820
SHRTFTB1S1(%) 0.0
O2B1S2(V) 0.805
OBD EOBD
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 18.0
ETC(°C) 90
SHRTFT1(%) -0.8
LONGFT1(%) 0.8
MAP(kPa) 21
RPM(/min) 3173
VSS(km/h) 96
SPARKADV(°) 2
IAT(°C) 15
TP(%) 0.0
O2S B1S12--B2S----
O2B1S1(V) 0.000
SHRTFTB1S1(%) 0.0
O2B1S2(V) 0.000
OBD EOBD
DTC_CNT 0
FUELSYS1 OL-Drive
FUELSYS2 N/A
LOAD_PCT(%) 36.9
ETC(°C) 87
SHRTFT1(%) 0.8
LONGFT1(%) 0.8
MAP(kPa) 75
RPM(/min) 2923
VSS(km/h) 88
SPARKADV(°) 20
IAT(°C) 16
TP(%) 10.6
O2S B1S12--B2S----
O2B1S1(V) 0.675
SHRTFTB1S1(%) 3.9
O2B1S2(V) 0.580
OBD EOBD
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 38.4
ETC(°C) 89
SHRTFT1(%) 1.6
LONGFT1(%) 0.8
MAP(kPa) 78
RPM(/min) 2955
VSS(km/h) 90
SPARKADV(°) 24
IAT(°C) 17
TP(%) 9.0
O2S B1S12--B2S----
O2B1S1(V) 0.715
SHRTFTB1S1(%) -2.3
O2B1S2(V) 0.645
OBD EOBD
DTC_CNT 0
FUELSYS1 OL-Drive
FUELSYS2 N/A
LOAD_PCT(%) 8.2
ETC(°C) 89
SHRTFT1(%) 0.0
LONGFT1(%) 0.8
MAP(kPa) 27
RPM(/min) 2702
VSS(km/h) 82
SPARKADV(°) 18
IAT(°C) 17
TP(%) 14.1
O2S B1S12--B2S----
O2B1S1(V) 0.175
SHRTFTB1S1(%) 0.0
O2B1S2(V) 0.540
OBD EOBD
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 16.5
ETC(°C) 87
SHRTFT1(%) -2.3
LONGFT1(%) 0.8
MAP(kPa) 61
RPM(/min) 2705
VSS(km/h) 82
SPARKADV(°) 14
IAT(°C) 18
TP(%) 21.2
O2S B1S12--B2S----
O2B1S1(V) 0.665
SHRTFTB1S1(%) 0.8
O2B1S2(V) 0.685
OBD EOBD
DTC_CNT 0
FUELSYS1 OL-Drive
FUELSYS2 N/A
LOAD_PCT(%) 50.2
ETC(°C) 90
SHRTFT1(%) 0.0
LONGFT1(%) 0.8
MAP(kPa) 100
RPM(/min) 2936
VSS(km/h) 90
SPARKADV(°) 14
IAT(°C) 17
TP(%) 76.9
O2S B1S12--B2S----
O2B1S1(V) 0.810
SHRTFTB1S1(%) 0.0
O2B1S2(V) 0.805
OBD EOBD
DTC_CNT 0
FUELSYS1 OL-Drive
FUELSYS2 N/A
LOAD_PCT(%) 55.7
ETC(°C) 87
SHRTFT1(%) 0.0
LONGFT1(%) 0.8
MAP(kPa) 100
RPM(/min) 3182
VSS(km/h) 97
SPARKADV(°) 14
IAT(°C) 16
TP(%) 76.9
O2S B1S12--B2S----
O2B1S1(V) 0.815
SHRTFTB1S1(%) 0.0
O2B1S2(V) 0.800
OBD EOBD
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 5.5
ETC(°C) 90
SHRTFT1(%) 0.0
LONGFT1(%) 0.8
MAP(kPa) 26
RPM(/min) 3082
VSS(km/h) 93
SPARKADV(°) 2
IAT(°C) 15
TP(%) 0.0
O2S B1S12--B2S----
O2B1S1(V) 0.000
SHRTFTB1S1(%) 0.0
O2B1S2(V) 0.000
OBD EOBD
DTC_CNT 0
FUELSYS1 OL-Drive
FUELSYS2 N/A
LOAD_PCT(%) 22.7
ETC(°C) 87
SHRTFT1(%) -2.3
LONGFT1(%) 0.8
MAP(kPa) 53
RPM(/min) 2774
VSS(km/h) 85
SPARKADV(°) 28
IAT(°C) 16
TP(%) 9.0
O2S B1S12--B2S----
O2B1S1(V) 0.695
SHRTFTB1S1(%) 0.0
O2B1S2(V) 0.565
OBD EOBD
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 8.6
ETC(°C) 88
SHRTFT1(%) -7.0
LONGFT1(%) 0.8
MAP(kPa) 27
RPM(/min) 2605
VSS(km/h) 78
SPARKADV(°) 2
IAT(°C) 17
TP(%) 0.0
O2S B1S12--B2S----
O2B1S1(V) 0.000
SHRTFTB1S1(%) 0.0
O2B1S2(V) 0.000
OBD EOBD
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 40.8
ETC(°C) 90
SHRTFT1(%) -0.8
LONGFT1(%) 0.8
MAP(kPa) 94
RPM(/min) 2516
VSS(km/h) 76
SPARKADV(°) 10
IAT(°C) 18
TP(%) 27.1
O2S B1S12--B2S----
O2B1S1(V) 0.635
SHRTFTB1S1(%) 3.1
O2B1S2(V) 0.630
OBD EOBD
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 40.8
ETC(°C) 88
SHRTFT1(%) 1.6
LONGFT1(%) 0.8
MAP(kPa) 81
RPM(/min) 2612
VSS(km/h) 81
SPARKADV(°) 24
IAT(°C) 17
TP(%) 11.4
O2S B1S12--B2S----
O2B1S1(V) 0.640
SHRTFTB1S1(%) 3.9
O2B1S2(V) 0.620
OBD EOBD
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 25.9
ETC(°C) 90
SHRTFT1(%) 0.0
LONGFT1(%) 0.8
MAP(kPa) 65
RPM(/min) 2622
VSS(km/h) 80
SPARKADV(°) 24
IAT(°C) 17
TP(%) 11.4
O2S B1S12--B2S----
O2B1S1(V) 0.260
SHRTFTB1S1(%) 0.8
O2B1S2(V) 0.615
OBD EOBD
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 27.5
ETC(°C) 88
SHRTFT1(%) 1.6
LONGFT1(%) 0.8
MAP(kPa) 65
RPM(/min) 2640
VSS(km/h) 80
SPARKADV(°) 25
IAT(°C) 17
TP(%) 10.6
O2S B1S12--B2S----
O2B1S1(V) 0.340
SHRTFTB1S1(%) -0.8
O2B1S2(V) 0.600
OBD EOBD
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 24.7
ETC(°C) 88
SHRTFT1(%) 3.1
LONGFT1(%) 0.8
MAP(kPa) 63
RPM(/min) 2600
VSS(km/h) 80
SPARKADV(°) 25
IAT(°C) 17
TP(%) 11.4
O2S B1S12--B2S----
O2B1S1(V) 0.215
SHRTFTB1S1(%) -1.6
O2B1S2(V) 0.590
OBD EOBD
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 27.1
ETC(°C) 91
SHRTFT1(%) -1.6
LONGFT1(%) 0.8
MAP(kPa) 66
RPM(/min) 2596
VSS(km/h) 78
SPARKADV(°) 24
IAT(°C) 18
TP(%) 11.8
O2S B1S12--B2S----
O2B1S1(V) 0.440
SHRTFTB1S1(%) 0.0
O2B1S2(V) 0.580
OBD EOBD
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 44.3
ETC(°C) 88
SHRTFT1(%) 0.0
LONGFT1(%) 0.8
MAP(kPa) 100
RPM(/min) 2625
VSS(km/h) 80
SPARKADV(°) 10
IAT(°C) 18
TP(%) 47.8
O2S B1S12--B2S----
O2B1S1(V) 0.185
SHRTFTB1S1(%) -7.0
O2B1S2(V) 0.640
OBD EOBD
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 46.3
ETC(°C) 90
SHRTFT1(%) -3.1
LONGFT1(%) 0.8
MAP(kPa) 24
RPM(/min) 2638
VSS(km/h) 80
SPARKADV(°) 2
IAT(°C) 16
TP(%) 0.0
O2S B1S12--B2S----
O2B1S1(V) 0.000
SHRTFTB1S1(%) 0.0
O2B1S2(V) 0.000
OBD EOBD
DTC_CNT 0
FUELSYS1 OL-Drive
FUELSYS2 N/A
LOAD_PCT(%) 5.9
ETC(°C) 89
SHRTFT1(%) 0.0
LONGFT1(%) 0.8
MAP(kPa) 67
RPM(/min) 2016
VSS(km/h) 61
SPARKADV(°) 15
IAT(°C) 17
TP(%) 12.5
O2S B1S12--B2S----
O2B1S1(V) 0.170
SHRTFTB1S1(%) 0.8
O2B1S2(V) 0.525
OBD EOBD
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 25.5
ETC(°C) 88
SHRTFT1(%) 1.6
LONGFT1(%) 0.8
MAP(kPa) 76
RPM(/min) 2059
VSS(km/h) 62
SPARKADV(°) 15
IAT(°C) 17
TP(%) 12.2
O2S B1S12--B2S----
O2B1S1(V) 0.220
SHRTFTB1S1(%) 3.9
O2B1S2(V) 0.630
OBD EOBD
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 25.9
ETC(°C) 91
SHRTFT1(%) 0.0
LONGFT1(%) 0.8
MAP(kPa) 76
RPM(/min) 2079
VSS(km/h) 62
SPARKADV(°) 15
IAT(°C) 18
TP(%) 12.2
O2S B1S12--B2S----
O2B1S1(V) 0.640
SHRTFTB1S1(%) 0.8
O2B1S2(V) 0.630
OBD EOBD
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 N/A
LOAD_PCT(%) 26.3
ETC(°C) 89
SHRTFT1(%) 0.0
LONGFT1(%) 0.8
MAP(kPa) 77
RPM(/min) 2084
VSS(km/h) 63
SPARKADV(°) 15
IAT(°C) 18
TP(%) 12.5
O2S B1S12--B2S----
O2B1S1(V) 0.650
SHRTFTB1S1(%) 0.0
O2B1S2(V) 0.615
OBD EOBD
User is offlineProfile CardPM
QuoteReply
greg123
post May 24 2008, 05:02 PM
Status: OFFLINE
Bump - so, no one on here know about Hyundai diagnostics?
If not, any suggestions where to go on the net to find anywhere that does?
Greg.
QuoteReply
hyunnychub
post May 28 2008, 10:13 PM
Drives: 2007 Accent 3 door 5 speed
Status: OFFLINE
id check the timing belt, maybye its a tooth or two of whack and thowing the timing out....
QuoteReply
> Link To Us
> Similar Threads
Data Trouble Codes
Forum : 1G (1995-1999) Accent
Dr. Hundi 18,339 20 Sep 5 2008, 06:42 PM
By: glizdunia2
O2 Sensor Fault
bmninada 153 8 Aug 28 2008, 05:14 PM
By: jtison
Vehicle Has Loss Of Power Hesitation
Forum : 1G-3G (1989-2005) Sonata
skr 82 1 Aug 25 2008, 08:32 AM
By: xx_ph4nt0m_xx
Stereo Wire Codes
Forum : 3G (2006+) Accent
Glock23 78 0 Aug 23 2008, 11:19 PM
By: Glock23
Codes P0304 & Po441
Forum : 2G (2000-2005) Accent
273HYPO 544 12 Aug 20 2008, 01:08 PM
By: Chelle
8th September 2008 - 03:26 AM
