allmet33 would probably know more about this since he has tapped into the harness at the amplifier for his semi-custom sysystem (aftermarket HU to factory amp running aftermarket cabin speakers). You may wat to shoot him a message or coax him out of the woodwork as he frequents this board.
Andyman brings up an interesting point about being wired the same (which I eluded to in my previous post). It seems like a lot of the wiring in these cars are the same (folding mirrors for example) but the stereo may not be. If the cars were wired for both stereos, I hypothesize the following to be the simplest solution to do this:
There would most likely be a wire harness that, in addition to power/ground/etc, runs wiring from the radio to the amp location in the trunk. From there there would be another harness that runs out to the speaker locations. these harnesses I would guess plug together for the base stereo and just pass the stereo amplified sound through to the speakers. For the Infinity system, these harnesses would be unplugged and the HU would send low level signals down these wires to the amp and then the amp send out the speaker level sound to the car though the second harness. However, I have a hard time believing that this is the case as it's a bit overkill with the wiring as Andyman stated. Either way, check that would be amp location in the trunk and see if there are any harnesses in that area that could be part of the audio system.
You stated that there is no harness or loom going to the radio (I assume you mean other than the one that cariies power, ground, speaker connections, etc) This would lead me to believe that the two cars are wired differently from the factory (or my above theory is actually true). Since the stocker HU powers speakers directly, it would make more sense to run speaker connections to the HU itself. The Infinity unit uses the outboard amp in the trunk to power the speakers and sends a line level signal to it via the harness (which runs wiring to the trunk amp not the speakers). Since your base model is most likely wired differently than the limited you are probably sending this line level signal to your speakers resulting in no sound.
To use your infinity head unit you will have to pull the amp from the limited and if you can get it out, the wiring. It may be easier to just cut tails off the harnesses and run the wiring yourself. Again, ask allmet33 as I think I saw somewhere that he had the wiring schematics for what wire (or pin) was what. Bottom line is you need an amp for that HU.
Then again I've had a lot of coffee this morning and I could be wrong about all of this. Allmet??? Are you out there with words of audio wisdom? You seem to have the firmest grasp on the azzy sound system.
This post has been edited by boppert1: May 21 2008, 01:32 PM
