Drives: 2008 Elantra SE Status: OFFLINE
I have a 08 SE.
I could have sworn I had seen the middle section between the two map lights light up before, but now it does not. Both map lights work, the dome light works. Does that center piece light up? or was I seeing stuff?
Drives: 2007 Elantra Status: OFFLINE
I have an '07 I just bought and the front tap lights do not go on with the middle light when the door is opened. Is this typical? Also, it looks like the glove box light does not stay on if the key is out and if you open the front doors. :unsure:
