2009 Sonata Mud Guards |
May 18 2008, 08:32 AM
Status:
Drives: 2009 Hyundai Sonata 4 cl
I just had these installed at the dealer as a part of "We owe".
The fronts fit perfect. The part number is 08460-3K000.
The rears fit, but not like the fronts. The clip that is under the car is pulling out and around the outside edge it is bowed. This is happening on both sides. The part number on the invoice for the rears is 08460-3K500.
My questions are: Did they use the correct ones on the rear? If anyone has an 09 with mud guards factory installed, can you check the rear fit and maybe get a part number off yours?
Thanks Tony
May 19 2008, 10:18 PM
Status:
Drives: 2009 Sonata
Bump
I too just bought an 09 GLS (my first Hyundai) and put the mud guards on myself. The front went on easily and fit like a glove.
The rear, now they are another story. I had trouble obtaining clearance for install and took the rear passenger tire off. Things didn't appear right but I tried anyway, the plastic clip (on guard) did not fit the lower fender well correctly and the self tapping screws didn't make the install any better.
I knew things were not right, removed the one guard and took it the set back to the dealer. If the dealer doesn't know this part number will not fit, who does? I gave the box to the salesman and commented the serial number on the guard does not match the one on the box. He said he would check into it. (thanks for all the help)
I would also be interested in the serial number from a guard installed at the factory so I don't needlessly take off the rear tire again and find out the next one provided by the dealer doesn't fit either.
Thanks for listening to my diatribe, can you tell I'm sore?
elinks
This post has been edited by elinks: May 19 2008, 10:20 PM
May 20 2008, 12:58 PM
Status:
Drives: 2009 Hyundai Sonata GLS 2.4
I went looking for one at my local dealers. They didn't have any for an '09 ......... showed me the one's for '08. The front would go on but there was a problem with the rear ones. The holes on the bumper and the pad do not align correctly ..... so I didn't get them. Waiting until they have the correct part. (Plus they were black and I wanted them to be body color).
I looked at their other '09 Sonata parked on the dealership and none of them had the splash pads installed - not even the limited one's so I'm just curious why it doesn't come fitted from the factory?
I couldn't find a pair on any websites as well.
Am looking for a pair of Splashpads, Window visors, Sunroof wind deflector and front bug-shield. If any one knows where to get these for '09 will they please share the info? (Weathertech.com has them but they have different colors for the visors and the sunroof wind deflector so I don't want those).
Thanks, MSKHAN
This post has been edited by mskhan: May 20 2008, 12:59 PM
Jun 3 2008, 06:32 PM
Status:
Drives: 2006 Sonata
Our daughter just got her new 2009 Sonata, wanted the mud guards but the car came without them. I Googled and found this forum. She had them installed yesterday and we could tell there was a problem as soon as we looked at them. We have a 2006 Sonata so we could compare the two side by side. It appears there's a slight change to that area of the car so the flaps don't fit the same. For the poster who suggested wait, it's early, the 09's have been out for a bit and it's almost impossible to even find a 2008 Sonata.
There is a gap of almost one inch between the car and the flap, and as you can tell from my screen name, we live in a cold climate. She's concerned that snow and salt will collect in that gap and cause problems. Seems like a logical conclusion to me. We'll bring it to the dealers attention and see what they suggest. I'm hoping they'll get a re-engineered flap that will replace what's available.
Aug 9 2008, 07:02 PM
Status:
The dealer got the new mud guards in today. The new rear part number is 08460-3 K600 (someone posted that part number in another thread). They fit perfect. The parts dept gave them to me no charge and I installed them.
Tony
This post has been edited by nutmeg: Aug 9 2008, 07:03 PM
Aug 19 2008, 01:18 PM
Status:
Drives: 09 sonata
I got my mudguards for 09 sonata and installed them. The fit is good. The instructions were good. Installing the front mud guards is easy. It is easier to remove the rear wheels before installing the rear mud guards. A drill is useful. You can find the Hyundai official instruction sheet that came with the parts, attached to this message.
