I was browsing around on hmaservice website for my 2005 Tucson. Looks like they show the brake fluid flush sequence in the: (first choose vehicle, TUCSON JM, 2005) Service Information Shop G 2.7V6 Brake System Brake System Brake Line Repair procedures
It shows the following order for "BRAKE SYSTEM BLEEDING" REAR RIGHT FRONT LEFT REAR LEFT FRONT RIGHT
The tightening specs on the bleed screw is 7-13Nm (5.2-9.6 ft-lbs)
Hope that helps someone, as the correct sequence is dependent on the vehicle.
