I purchased a new keyless remote fob for my 2002 santa fe and followed programming instructions and eventually was able to program the new remote. But, I did not realize I had to program my existing remote at the same time. Since, I have retried programming both remotes many times with no success--the new one works, but the old one won't. The instructions were: 1) Locate switch under dash, behind fuse box; 2) Turn ignition switch on, but don't start engine; 3) Wait 5 seconds, set memory switch to SET position; 4) Press remote LOCK button; press second remote transmitter LOCK button; 5) Set memory switch to OFF; 6) Switch ignition OFF. 7) Confirm programming by locking and unlocking vehicle.
I have tried varying how long I hold remote lock buttons and at step 6) removing the key from the ignition, also waiting more than 5 seconds at step 3), but only the new remote works and the old one doesn't. I tried searching this site for past answers to this question, but turned up no results. Can anyone help, or do I just pay the Dealer to do it? Thanks for any advice. gmilkins
