[need Info] I30 |
May 14 2008, 02:57 PM
Status:
Drives: 06 Sonarta 2.4,04 Falcon V8 Ute, 08 i30 CRDi poverty pack manuel
QUOTE(echocae @ May 14 2008, 01:01 PM) for lowbeam ussually they have some ventilation :) to reduce the heat :) as for HIGH BEAM/FOG Light is illegal to have more than 4500K HID :)
in HID the colour is in K
3500K = yellow (same as stock) 4500K = Yellowish/ White 5000K = White (like most of european cars) 5500k = White (like most of european cars) 6000 - 6500k = Sunlight WHITE <-- the brightess light 7000 - 8000k = White/ blueish 8000 - 12000K = BLUE/ Purpleish 12000-16000K = Purple
i just need the exact bulb type/size.. so i can order the HID properly.. so u guys think is a H1 Size for LOW beam and also H1 size for HIGH beam?
so anyone that know.. let me know!! [right][snapback]161115[/snapback][/right]
Do they just replace the stock globes ? i talked to a guy that was incharge of emergency work, he was telling me those type lights same as come stock with euro cars are expencive but they, give a light like daylight and run at a much cooler temp than equivalent hallogen and take less power to run them. he said to run 1,000 watt halogen they used a diesel generator and if the fell over they could start a fire, one of these lights you are taking about could run off a small battery and give a light like daylight but still be cool. just he seemed to beleave you had to get more than just a globe, he used them on his Harley and Harleys use 55W low 60W high halogen stock he led me to beleave you need more than just a replacement globe and that it was not cheap. i used to just replace the 55W 60W globe with 55W 100W and get good results much brighter light, those Blue lights blind oncoming traffic. but they are stock on most euro cars and have been passed road worthy so must be ok. just i notice they can blind you more than normal hallogen, i think it has something to do with the blue colour.
May 14 2008, 06:00 PM
Status:
Drives: 07 Mazda3 MZR-CD 2.0, i30 admirer ... (tried to buy one)
As Lakes indicated, from what I understand from researching this topic two years ago, HID systems are a COMPLETELY DIFFERENT SYSTEM to the standard halogen globes you find in most cars. So it's not really HID "globe", but an entirely different system of Xenon gas burning in the specially housed headlamp. They are VERY VERY bright (hence High Intensity Discharge) and there is a distinct "cut-off" in light across the road.
HID systems from what I understand, has a ballast that fires up the globe at some thousands of volts (like a spark plug), before the system settles down to around 180 volts while it is running. You will notice this start up "flicker" when some BMW's and some Honda Accord Euro and some Libertys turn their lights on.
As to retro-fitting, beware. Firstly, because they probably do not satisfy ADR rules and the coppers won't have any issues issuing a fine if they find you with it. Secondly, retro fitting such a complicated system will be expensive, because you're talking about a whole new headlamp set, not just the globe. Thirdly, the ADR homologation testing for cars before they are approved on sale for the Aust market is there for a reason - so the public can rest assured the system works without detrimenting anyone. As it is, these HID systems do blind a lot of oncoming cars (when the HID car hits a dip and momentarily beams up for instance), so it's just a safety courtesy to consider what a retro fitted HID system could do to oncoming cars.
Lastly, you see a lot of "HID" blue or white light globes on sale at auto shops for $20/$30 - these are NOT HID globes, but only simulated ones - the light becomes white because of the Xenon gas in the globe - I've tested them myself and strongly suggest AGAINST them, because the white light actually doesn't define objects as well as the standard yellow light, and this is especially true in the rain, when it can get downright dangerous as potholes are missed. White light and rain don't go together, unless it's a true HID system.
If you want to get more light out of your current system, may I suggest an alternative that I've done over the years - get a set of Narva +50% halogen globes from Repco. These globes are rated the same as the normal globes, but the Xenon gas in them does make them a lot brighter. They do get dimmer as the years past - my ones lasted 3 years and by the time they were on their last legs, they were any brighter than the usual globes, but I got about 2 years worth a really bright light from them. And then, here goes, at the risk of contradicting myself, you might want to consider *incrementally* and *slightly* adjusting your headlamps up a little, to have the light cover more road ahead of you - I find that manufacturers are very conservative in this area ie. the headlamps are pointed too low. You need to be careful not to point them too high when adjusting them (just remember the number of clicks of turn when you're adjusting it) - do it against a wall about 10 meters away. The problem is the manufacturer's standard low setting actually can be dangerous for the driver on dark highways, because at 110km/h an hour a lot of ground is covered every split second, and a light that only covers 5 or metres ahead is dangerou, but set too high, you could blind oncoming cars, so you need to find a balance.
Anyway, in summary, HID system retro-fit? Don't recommend it ..... :o.
May 15 2008, 12:57 AM
Status:
Drives: 08 i30 SX CRDi, 04 Honda Jazz VTI-S Turbo, 06 Honda CBR 1000RR, 05 Honda MDX, 07 Ford XR5 Turbo
Yeah is very2 easy... the wiring is straight forward.. :)
btw dazz do u know what bulb they using for LOW BEAM?
i got quoted differently from alot of dealer from this forum it said H1 from 1 dealer they said H4 (hi/lo) <-- which is ridiculous and from dealer that have the bulb in their hand they said is H7
so do u guys know? because i need to ORDER ASAP..
LOW BEAM HEADLIGHT - is the one inside the LENS / Near the indicator, can any one pull them out from the casing and read the NUMBER? (size in H1, H2, H7, ect.), atm i cant check it coz my i30 coming in next week
This post has been edited by echocae: May 15 2008, 12:58 AM
May 16 2008, 12:53 AM
Status:
OK now i have an answer for the headlight bulb size Hyundai Australia told me is H1 and the 3 Hyundai Dealer (2 WA and 1 VIC) they open the bulb from the lens and check physically from i30 told me its H7 (12v/55w). so.. i think i gonna take the risk and go with H7 and now i already buy H7 HID 6000K(which is the legal light requirement of HID in projector headlight) for only $120 , and i look at the instalation guide its seems the same as my OLD car HID (only takes about 10min installing it). now I just need the CAR to come :P and i gonna take photo of the light with and without the HID here sum pics of the HID: (IMG: http://i220.photobucket.com/albums/dd165/echocae/item/HIDbaru.jpg) (IMG: http://i220.photobucket.com/albums/dd165/echocae/item/hidbaru2.jpg) (IMG: http://i220.photobucket.com/albums/dd165/echocae/item/HIDbaru3.jpg) and for instruction manual of HID please copy n paste link below (due is big size) Page 1 ManualPage 2 Manual
This post has been edited by echocae: May 16 2008, 02:42 AM
