There are six screws you need to remove.
2 on the curbside of the door panel 1 in the pull handle 1 behind a cover in the release handle cove 2 on the fender side of the panel
Once you remove all of these, tap upwards firmly with your fist on the bottom of the panel. Once it pops up, you'll need to hold onto it to disconnect the plugs for the power windows, locks, etc. There are two plugs and the door marker light to disconnect. Once you do that, you can set the panel aside completely and get to work. Re-install in the reverse. Best of luck.
This post has been edited by lovemysantafe: May 27 2008, 08:10 PM
