QUOTE(turbo1600 @ May 15 2008, 07:12 AM)
I borrowed some hex fitting sockets from a friend and I can confirm that it is indeed a 17mm hex socket, so if you are game to do your own servicing, go for it.
The filter is cartridge based, its located near the top of the motor. Where the letters "CRD" on the engine dust cover are, just south of that towards the radiator is a black cannister with a hex fitting, I havent measured that up as yet.
How do you take the dust cover off without damaging it?
[right][snapback]161305[/snapback][/right]
Was going to say the sump plug is 17mm, i saw the filter, just what will you do to remove it without a mess? it's upside down like i thought, as the oil leavel is lower when hot as you first turn motor off, but higher when cold. let me know what you use to catch the oil as you remove the filter, some of these new diesels use two oil filters.
