QUOTE(wfranklin @ Jun 2 2008, 11:01 AM)
Automatic transmissions are fluid-driven. The trans fluid in your Elantra cools, lubricates, and cleans your transmission throughout the driving process. In neutral, if I'm not mistaken, there is NO fluid circulation so you risk overheating your valve body and other transmission components. The only Elantra that benefits from shifting into neutral when coming to stops or coasting is a manual transmission Elantra, where the clutch fluid is only used to build pressure to disengage/engage the clutch.
Are you speaking from experience about this particular tranny design? I know at least some auto trannies can be shifted into neutral with no adverse affects because the tranny oil pump is driven by the engine output.
Best bet would be to contact the dealer, or a transmission shop that has actually worked on one.
Shifting into neutral may be illegal in your state.
This post has been edited by dac122: Aug 28 2008, 07:57 AM
