Hello!
Check how much oil u'r engine has, and do it fast!!!! I had experience with this problem too! Not to play with this one...! Btw: what gas value RONxx do u use?
About those windows: when u remove dor panel u can see some bolts - they are holding the motor and the aluminium carrier on which the window slides up and down(Lantra 96 has like this). My advice: if it is only the power cable there's no problem fixing it, but if the wire has gone off (like mine-plastic bearer broke and while the motor was turning and I got a 'weird' knot out of that wire :grin: ) and some bearer had broken I suggest u leave it cause it'll take too much of u'r time. Btw: after I saw it was hopeless to fix, I removed the motor and all that stuff inside the door, blocked the window from sliding down and put the door panel back on.
cheers,
Mark
This post has been edited by marek46: May 9 2008, 08:36 AM
