QUOTE(bwatson @ May 5 2008, 05:43 PM)
Does anyone know of any cold air intakes for a 2007 Santa Fe 3.3L? Or for that matter any after market performance parts that may help with gas millage?
So far, I've only been able to find a K&N air filter.
http://www.knfilters.com/search/product.aspx?Prod=33-2378TIA
I installed the K&N Filters on both my 07 Azera and 07 Santa Fe over a year ago. I am not sure if they helped with gas mileage or power but they definitely last a whole lot longer. :)
As far as a cold air intake is concerned, save your money. The 3.3 does not generate enough underhood heat to create an intake problem.
Even if you could purchase one commercially, you would never recoup your cost via increased efficiency or power. The 3.3 just isn't considered a high performance engine and there is nothing you can do to change that.
I installed a cold air intake in my 2004 Cobra. That made sense and actually helped with the HP, but not in my 3.3 Azera or 3.3 Santa Fe.
The only thing that has helped with my gas mileage is inflating the tires about 4 psi over the recommended amount and avoid jack rabbit starts and quick stops.
By the way, the over inflation of your tires will also give you a more even tire wear and the vehicle will handle much better.
Good luck and enjoy your Santy. They really nice vehicles. Everytime I see a Lexus, I think it is a Santa Fe. :clap:
The only difference, mine is several thousand cheaper. :thumbsup:
Okay, okay, maybe the Lexus is just a little bit nicer. :whistling: But not that much. :beer:
David <><
This post has been edited by david-paul-1: May 6 2008, 03:41 AM
