> 93 Excel
top gun
post May 5 2008, 11:01 AM
Drives: 93 excel
Hello to all. My name is Rich and I have a 93 excel that has only 24,000 miles and the car as you can guess is like new. Now, Late last year my daughter was drining it when suddenly it began to shake and knock and shut off. It would still start but would shake and knock wildly. Anyway I had it towed to my local mechanic and found that one of the rocker arm shafts had broken. He said it was common with these engines and that they are considered thrugh away motors. So finally He replaced both shafts and the car ran fine although a little noisy from my guess an inproper valve lash adjustment. I say inproper because just a few weeks later the car broke down again the same way as the first and so I decided to have a go at it myself. I took of the valve cover and what do I see, The rocker shaft for the exhaust side is broken in half. I would like to salvage this little car because of the milage and when it is running it is really great on gas and is good and tight just like a new car. when I took the shaft off I di notice that the shaft he replaced on the intake side seems to have been put in backwards because the bolt holes are off center and the valve adjusting screws are not centered on the valve stems. MY question is , Could this idiot have cased this to happen a second time or is this a problem with these motors?.....................Rich
ratchan
post May 17 2008, 02:49 AM
Drives: 1987 Hyundai Excel GL 1.5
QUOTE(top gun @ May 6 2008, 03:01 AM)
Maybe she didnt like your daughter :P My girl has 'died' on other drivers since I brought her but when it comes to me, she works like a charm.
Onto the fact of this mechanic. It is possible that he did foul up when he was fixing the motor. There are some mechanics that havent seen a Hyundai motors before or even tried to fix one either. Are you sure this guy knows about Hyundai motors?
maxwell12
post Dec 26 2009, 03:15 PM
Drives: HYUNDAI EXCEL
Hello the rocker arms break on alot of hyundai excels..this is a common problem, especially on the back or rear rocker when facing the valve cocer from the front of car.
The bolts have to be torqued to around 19 foot pounds if i recall, then you MUSt adjust the valves.
Sounds like this guy did not put in a new rocker arm shaft, but just reversed it..the reason I say this is because someone did the same thing to mine..it is a faster fix from them so they use the same old broken part, just reverse it.
I would tlk to the mechanic and tell him to replace fro free if that was the case.
good luck
sanjeet
post Dec 29 2009, 11:49 AM
Drives: 1992 Hyundai Excel LS
Same thing happened to my 1992 Hyundai, I found a replacement shaft off an old Mitshubishi at the wreckers (cheap as chips at about NZ $8) when refitting I would bring down the torque slowly on each bolt for example start at 5ft pounds and slowly increase to get the correct torque rather than go in at 20 ft pound first off, I need to reset the tappets, I have just been using it for short trips and they are great on gas and very quick as well.
My shaft was broken at one end and I did not know what had happened until I took off the rocker cover (Exhaust Shaft)
No New Posts 93 Hyundai Excel Acceleration Problem.
Minor jerk/loss of power while shifting from 2nd to 3rd gear.
6 ali2128 373 12th March 2010 - 09:14 PM
Last post by: kurtdaniel
No New Posts 93 Scoupe With No Power
1 daddy1605 120 9th February 2010 - 03:26 PM
Last post by: sounds like...hyundai
No new 93 Octane Fuel
28 RobPecnick 847 6th January 2010 - 10:15 PM
Last post by: litesong
No New Posts Excel Vs. Similar Engines
Which vehicles can engine parts be sourced from?
2 milk8man 260 7th October 2009 - 08:10 PM
Last post by: sanjeet
No New Posts Excel 93 Mass Air Flow Sensor Problem
do I need the mass air flow sensor?
4 lsotto2005 1,258 7th October 2009 - 07:18 AM
Last post by: juanestefani
16th March 2010 - 06:45 PM
Privacy Statement
